Old 02-24-2010, 02:03 AM   #181
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Add me, add me, I got Morgan's kit
Pics from the install:
Unpacking the beast:
No going back now
Yaay, one step closer
Trying to figure things out... I mean hoses
And when I was done, I took it for a ride:
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 03-10-2010, 05:26 PM   #182
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
list updated, cite me if i've overlooked anything
Old 03-10-2010, 06:01 PM   #183
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
THANK YOU FOR NOT INCLUDING ME
Parmas is offline   Reply With Quote
Old 03-10-2010, 06:07 PM   #184
Old 03-10-2010, 06:32 PM   #185
whooppee777
didnt you get the memo? you dont count
Old 03-10-2010, 10:58 PM   #186
Morgan
Morgan's Avatar
Drives: 07 MM LB
yay, amended list! I'm glad someone else gets to enjoy the kit
but it was the unfortunate gateway to other.... ummm.... less reliable means of forced induction!
fun nonetheless!
Old 03-11-2010, 11:53 AM   #187
whooppee777
what the hell is that?
Old 03-11-2010, 03:18 PM   #188
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I've heard of those... I don't think I've ever seen one before...
Old 03-11-2010, 10:35 PM   #189
Morgan
Morgan's Avatar
Drives: 07 MM LB
Originally Posted by cdydjded View Post
Merkur XR4Ti
+1 for you sir
Old 03-13-2010, 11:58 PM   #190
advocate
Drives: car
Main page needs updating: Echo's Blitz Kit survived the crash and has found its way onto his Vitz RS 2.0.
Old 03-31-2010, 11:55 PM   #191
MANSETH
KAVINT
Drives: KAVINT
MANSETH : KAVINT
JIMZE SUPERCHARGE
MANSETH is offline   Reply With Quote
Old 04-05-2010, 07:06 PM   #192
Steven Dionne
Turbo lover
Drives: Toyota Cressida1987/Yaris 07
You can had me,
yaris 07 Greddy turbo kit from xb with custom fmic
Yaris 07 track/winter
Cressida 87 7MGTE
Steven Dionne is offline   Reply With Quote
Old 05-27-2010, 08:32 AM   #193
rector
rector's Avatar
Drives: vitz turbo
i dont know if i can be added to the list
but here is mine......
ENGINE:
1NZ-FE with Greddy turbo kit
alumium oil pan
60mm exhaust
custom made intercooler
trd radiator
wr engine damper
hks ssqv bov
apexi power intake
turbosmart bleed valve
starlet glanza map sensor
starlet glanza inlet air temperature
toyosport oil catch tank
TRANSMISSION:
stock gearbox
fidanza flywheel
exedy clutch stage 1
SUSPENSION:
D2 coilover
rear brace
progressive rear sway bar
ELECTRONICS:
apexi boost meter el2
apexi exhaust temperature meter el2
apexi unit el2 system
apexi power fc standalone ecu with commander
apexi turbo timer
INTERIOR:
leather steering wheel
ts seats
leather gear knob
momo handbrake
subaru pedals
EXTERIOR:
standar vitz rs look
toora rims 15x7 et+35
195/50/15 michelin pilot sport
electic folding mirrors
all badges removed
i am sure that i forget some things ......but never mind
here are some pics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
rector is offline   Reply With Quote
Old 05-27-2010, 11:51 AM   #194
^ nice set up! Have you dyno'd that?
Old 05-27-2010, 04:43 PM   #195
Parmas
Parmas's Avatar
Nice setup... I like the position of the turbo there!
I wish it was mine in that position of the brake fluid tank... yours makes it a more clean setup
What size is that turbo by the way?
Old 05-28-2010, 02:22 AM   #196
rector
rector's Avatar
Drives: vitz turbo
cali yaris i still havent managed to dyno it as it was road tuned.the car is on stock internals and low boost (0.4 bar) so i am not expecting much.
although i have tested the car with my best friend that has a starlet glanza dynoed at 142hp and i was happy with the result as i was 2 cars in frond of him passing the 400m.
by the way love your yaris!!!!!
as for parmas : the turbo is a greddy tf035hl (mitsubishi manufacturer) but i have tried so much to find some spec of the size of the tubo etc but came to nothing.maybe if you see some pictures will help.
have you got any ideas about the size or has someone the spec of this turbo??
Old 05-28-2010, 08:31 AM   #197
Parmas
Parmas's Avatar
It looks slightly bigger than mine. It is possible to be a T3 size, mine is a T28. I couldn't imagine it to be bigger as I have doubt it would fit in there. By the way, did you hardened the rear engine mounting? ..... as it is highly possible you hit the rear panel with the turbo and there is a chance you crack your exhaust mainfold
Do you know how much diameter in inch is the intecooler piping?
Also noticing the 2nd picture of the engine, it seems like your turbo can be watercooled. Could you tell us why you didn't install the water lines?
Old 05-28-2010, 10:52 AM   #198
Guys this is a great discussion, it should have its own thread - not in the "list of boosted members".
Can a mod split off the posts about this particular build? I want to ask some more questions, too!
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 10:45 AM
EBAY Seller Alert for Yarisworld Members redyaris DIY / Maintenance / Service 29 07-02-2007 09:23 PM
HiLEDs discount on High Intensity LEDs for YarisWorld members! Hileds Sponsors Classifieds Area 103 04-06-2007 12:28 PM
Yarisworld Parts List - Work in progress vodkalush General Yaris / Vitz Discussion 5 02-13-2007 06:12 PM
