Old 03-10-2010, 08:21 PM   #11
lily
lily
Drives: white plane jane
I need some help from this install.
Got an '07 Yaris HB, base model, auto.
I did the 2 button setep from CTScott's PDF write-up.
I cannot get the 'cruise' to work after this mod.
What I did was soldered two resistors in series: a 270 and 380 for a 650 resistor. Then soldered the series as shown on the PDF for the 2 button setup.
I ran a wire to the PIN 40 on the ECU and grounded the other wire, but still nothing.
My questions are:
How far does the wire going into the ECU have to "stick" out to touch inside the ECU?........I have maybe 2 or 3 wires that stuck out from the harness, is that enough "contact" to make this work?
I grounded the other wire by just screwing/sandwiching into a grounded source on the driver's kick panel, <<< is this "good grounding"???
Is soldering a good idea to connect the series? <<< I soldered because the pins behind on the push buttons I got from Radio Shack were too small to work on.
I hope I am clear about my questions. It has been raining here so I would like some help soon so I could use this feature on my upcoming road-trip.
Thank you for your time.
lily is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
