Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
http://spillcam.tk/
------------------------------------------------------------------ this had already been proposed by Dutch engineering firms what you are missing is: a way to keep hydrates from lifting the vessel off the bottom while it is put in place. 10 % of that flow is gas which turns to ice immediately, not a simple problem and, you'd need massive rocks and many of them to hold it to the ocean floor the float idea you posted..., suck oil up, could not contain or lift all the oil to the surface, you'd need impossible sized pumps and pipe diameters which exceed the capability of current engineering. you'd get some but only a fraction...the pressure of the oil itself is needed to lift it one mile high. that diagram is impossible to design with enough capacity to get all the oil... not gonna happen. or...dropping a hull on the ocean floor...this is not feasible because the BOP must be controlled, and not just hidden away under some large hull. to cap it while the BOP is still leaking leaves a timebomb of erosion of the drill hole below the bop, and like a flooded stream under a low bridge, eventually the oil will erode the shaft, blow the bop off, and create an uncappable hole and oil would spew out with about 20,000 psi. then it really would be a disaster what really pisses me off is: the saw cutting the riser failed and got stuck. but it made an awesome cut up to that point. instead of saying, screw it, lets unstick that saw and send another one just like it down, so what if it leaks for 3 more days....we'll get a clean cut... instead they made the panic decision to clamp-cut, making it -impossible- to fit the cap on tightly, and now the cap is nearly useless. the news stories about, oh we are adjusting the cap and will not know until we close the vents....well I have been looking at the 12 ROV cams, and that cap will never, ever be able to stem the flow unless a new cut is made, or they unbolt the riser and install a whole new BOP on top. BP is screwing this up. sure it is a tough job trying to contain oil at 5000 psi at the BOP (and 20,000 psi if it was left to run wild without a BOP in place), that is an incredible amount of pressure. but they really cheesed the cut and cap operation. it makes me dumbfounded I predict BP will be bought out by another oil company when the stock plummets enough, and that is the end of BP making decisions in drilling operations moving forward. I have seen enough huge engineering projects in my day, this thing is cappable if they stop screwing around, say to everyone, "Hey this is gonna leak like a sombitch for 1 month, but then we will definitely cap this thing' and go develop the massive engineering to drop a huge ROV down there with huge tools and just put a new damn BOP on there and stop dicking around with tiny useless actions with the existing ROV's (which were designed for day-to-day operations and are not capable of really big jobs) I live next to iRobot and I will bet the engineers in there could build a freaking beauty of a disaster-rated all-in-one can-do-anything ROV. I bet the oil industry now will be mandated to have such a 'super robot' built and ready moving forward...I hope anyway there is no problem drilling for oil 1 mile deep and then 2 more miles into rock. the problem is bypassing safety, which is what BP made Deepwater engineers do. rush the job by 1 1/2 day to save only 2 or 3 million dollars. that is what happened. Oh the drilling mud will keep the oil down, yes it did. so lets try seawater, it is faster and we can plug this and move on...it seems to be holding... Oh..oops seawater is not so good as holding down gas bubbles. plus the fact the rubber annular was broken a week prior, preventing the BOP from being able to do it's job as a blow out preventer and turned it into a blow out enabler. I, as well as 200 million other people, just want to scream. Last edited by 127.0.0.1; 06-06-2010 at 12:21 AM. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 02:55 PM |
| When should I start using synthetic oil?? | trwxxa | DIY / Maintenance / Service | 68 | 06-29-2009 07:16 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
