08-03-2010, 10:32 AM | #1 |
Drives: Yaris 1.3 SR Join Date: May 2010
New Petrol from Shell, claims to increase MPG!
Over here in the UK, Shell are running an ad that claims they are replacing the usual unleaded petrol for their new Fuelsave Unleaded that can allow you to save the equivelant of 1 litre of fuel per tank full. So, the average UK fuel tank is 60 litres, this is an increase in economy of 1.6% in very rough calculations.
More info: Shell Fuelsave Now, I know a reasonable amount on internal combustion, and the way I see it is that this fuel improves the smooth running of your engine by using an additive, allowing the engine to produce less friction. This means it takes slightly less energy to turn the wheels, hence less throttle needed and a saving of fuel. So you will see a saving if your driving style stays the same and you dont go around full throttle most of the time Right, so that should mean that you get more power to the wheels at full throttle with the new fuel than before. That surely must be a great news to all If the MPG saving is 1.6%, that should mean 1.6% power increase. Not great, but as the new fuel is the same price, and you need it anyway, thats a free 1.6% increase. |
08-03-2010, 05:26 PM | #2 |
Pretty green Yaris Verso
Drives: Toyota Yaris Verso Join Date: Mar 2009
Sounds good to me, as usually there's a high premium to pay for better fuel.
Thanks |
08-03-2010, 05:38 PM | #3 | |
USAF_SrA_E-4
Mmmmmm idk I ain't buying it , however Shell is the only gas I put in my Yaris
08-03-2010, 07:20 PM | #4 |
Drives: 2010 Yaris Sedan Join Date: Feb 2010
Shell and Quick Trip give me noticeably better mileage than others, so thats were my moneys going
08-03-2010, 07:45 PM | #5 |
Drives: toyota yaris yrs Join Date: Jun 2007
I use caltex and shell. But to me BP unleadead +10 pct meth does better than
both.Better performance and fuel economy. |
08-03-2010, 08:22 PM | #6 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
I would like some good old fashion gas with MBTE additive!!!!
Okay, gas that is not oxygenated. Not this ethanal crap... that is said is so environmentally friendly
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS - (Click below to see Gaslog): Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
08-04-2010, 06:29 AM | #7 |
My next fill up will be on this new shell stuff, so I will see what its like.
So does my "same performance for less throttle = improved performance for full throttle" thoery stack up for this stuff compared to normal petrol? |
Similar Threads | ||||
Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 04:15 AM |
Will I get my increase in MPG at 5000 miles? | YarisOwnersDad | Fuel Economy Forum | 20 | 08-14-2009 08:47 PM |
does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
Hmmmm noticed substantial mpg increase with nst pulley... | YarisSedan | Performance Modifications | 11 | 04-16-2009 04:42 PM |
Pure Acetone increase MPG | YenOfIrrelevent | Fuel Economy Forum | 29 | 01-21-2009 09:16 AM |
