Old 01-25-2007, 07:55 AM   #19
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
2007 Lift Back and mine is fine....................
sambo883
Southern ,NH
sambo42xa
sambo42xa is offline   Reply With Quote
Old 01-25-2007, 08:33 AM   #20
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Arrow We are trying to figure that out...
Originally Posted by d2dailly View Post
everyone with a sedan it turns off when you go to the lock position, everyone with a LB it turns full bright when you go to the lock position
What makes you say as if you know for sure?
Do you work for Toyota?
Please let us know so we can put this to rest.
See, I have a sedan and I'd pretty much swear mine worked all the way up too.
I am pretty sure that it was working like that and went out when I started backing out of the driveway.. I saw it go out.. What if the sedan has some sort of defect and they are going out? I may go to the dealership and get them to check three or so sedans and see..
Go4th is offline   Reply With Quote
Old 01-25-2007, 10:10 AM   #21
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
My liftback stays at full brightness when its all the way up.
Old 01-25-2007, 10:58 AM   #22
MWill517
MWill517's Avatar
Drives: '07 Yaris Sedan Barcelona Red
Sedan: When my headlights are on and I go past the "notch", the speedo turns off and the lcd clock/odo goes full bright. I use it that way at times such as rainy days when I need lights on and it is light outside as well. The speedo is easy to see most all the time, but it helps to see the dim lcd display.
MWill517 is offline   Reply With Quote
Old 01-25-2007, 11:05 AM   #23
Go4th
Go4th's Avatar
starting to develop a pattern now..
Old 01-25-2007, 11:37 AM   #24
Violin
Violin's Avatar
Without lights on the liftback, we have no speedo. There's nothing to see but a needle. That's why the difference.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
Shift knobs with lights? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 0 09-20-2006 04:09 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
