![]() Drives: 07 Yaris Hatch Join Date: Dec 2010
Changed water pump, now have a CEL?
I just changed my water pump a few weeks ago, and as soon as I started the car after I got done I was showing a check engine light. I took it to the local advance/auto zone and had it checked out. Error message showed up as bad camshaft sensor on banks 1 and 2. Now I was puzzled both by the fact the Yaris doesnt have two seperate banks, and the fact I didnt touch anythign electronical other then dosconnecting the battery and alternator. Do any of you guys know what I can do to get it to shut off?
Ryan |
Check the connector on the Camshaft Timing Oil Control Valve, which is located just above the alternator. Many have damaged either the connector or sensor when tightening the alternator.
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
