Old 12-29-2022, 12:25 AM   #1
sh0rtlife
the link in the post above yours is still good...
Old 04-16-2023, 04:54 PM   #2
matt4x4
Drives: 2008 Yaris, 4dr sedan, 5 spd
Nice that I found this, looks easy enough.
Long road trips the cruise on my '08 manual, sedan w/power will come in handy, just worried about any loss of power on the hills with the 1.5L, drove a bit into the mtns through the hwy1 hills a little bit into the rockies (Banff/Nakiska/back road hwy 40) back to the big city, and I had to downshift sometimes, just day 3 driving the cutie Yaris. I still need to fine tune the rpm gear change on the manual, I go by sound of rpms, but am in it for fuel sipping.
Link worked for me
Thanks
matt4x4 is offline   Reply With Quote
Old 04-16-2023, 04:56 PM   #3
sh0rtlife
i know with an auto running the coastal range it will downshift and handle it just fine..with a manual your kinda on your own there as to wen to downshift and pop out of cruise
Old 05-28-2023, 10:00 AM   #4
hypersata
Drives: Yaris 2014 GCC LHD 4AT
Hello there,
can anyone help me with the Aftermarket kit for Yaris 2014 GCC - Cruise control?
I cant find something useful on the internet myself.
as I discover from this forum, GCC versions are not supporting OEM CC.
any help would be much-appreciated Folks.
For the reference
NCP151L-CEPRKV
MHFBW9F36F50027xx
2NZFE 1300CC 16-VALVE DOHC EFI
hypersata is offline   Reply With Quote
Old 07-19-2023, 02:01 PM   #5
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
I have a 2009 Yaris 2 door hatchback with a 5-speed trans. It has factory installed cruise control and 332,000 miles on the odometer. The cruise control recently stopped working. I've tried to activate the CC however the yellow CC light in the instrument cluster does not illuminate, nor will the CC operate. Hoping the culprit was a blown fuse I inspected all fuses - all seem fine. Then, hoping it was the CC stalk (hoped that the switch wore-out) I replaced the stalk with a brand new OEM stalk #84632-08021 Speed Control Switch. The CC still doesn't operate. I checked the original stalk with a multi-meter and the original stalk has continuous power while the stalk button is kept pressed in, but as soon as I remove all pressure off the button continuous power is disconnected. I assume that's how the on/off button in the stalk is supposed to operate(?).
I'd really like to get the CC operational again. What should be next course of action? I suspect that even if either CC disengage switch on the clutch and brake pedals are faulty, the CC indicator light on the instrument cluster would still light up. Is there a relay that powers the CC? Again, the yellow CC indicator light on the center instrument cluster does not illuminate. Other than the CC not being functional, everything else works flawlessly. Bad relay? Bad ECM? Or?...... Any advice that you may provide to restore my CC is greatly appreciated.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 07-19-2023, 03:08 PM   #6
sh0rtlife
10-1 odds are its your snail AKA spiral cable, its actualy one of the hardest wearing parts on a car as your basicly bending wires back n forth every time you turn the wheel
9-10 times when a FACTORY CC fails it can be traced to 1 of 2 things, a bad spiral cable or a bad brake switch..and before you go and check if your brake lights work..remember that it has a secondary set of wires on the switch SPECIFIC to the cruise and not part of the brake lights
yet the first thing anyone replaces is the cruise stalk thinking its that....belive it or not ive yet to find one dead that wasnt physically visually damaged on the outside...fun side note is that said switch sometimes replacing it with other bad parts will give a false positive and youll have working cruise for a single use...its because you got lucky...i chased that demon earlier this year on an XB..intermitent CC working..was a combo of the spiral AND the brake switch both were intermitently bad
Old 12-17-2023, 07:11 PM   #7
nickshch
Drives: Toyota Yaris 2011 AT LB
I have installed just the Cruise Control Switch to my Toyota Yaris 2011 Liftback AT (made in Japan, for US market) and that worked. Amazing! Thank you very much guys. Bought it on Amazon for $15
nickshch is offline   Reply With Quote
Old 02-17-2024, 05:56 PM   #8
steelwheels
Drives: 2010, 2 door hatch, MT
kevinj93 thank you so much for uploading the manual to google drive and sharing it on this forum I will now be installing CC in my '10 2dr mt hatch!! seems like all I need to buy is the clutch switch and the stalk. amazing.
here is the link to the file again just to make it super easy to find:
https://drive.google.com/file/d/1Bfc...fZXIDu7wL/view
steelwheels is offline   Reply With Quote
Old 03-15-2024, 11:14 PM   #9
CrimsonEclipse
Drives: .
Finally finally FINALLY getting to the CC mod
Looking at the install guide, it seems to imply that my 2011 M/T doesn't need wiring installed. Looks like it already has a clutch switch installed, and it seems that all I need to do is install the stalk.
Does that sound right?
(would be great if I can do this for $35)
CrimsonEclipse is offline   Reply With Quote
Old 03-16-2024, 09:00 AM   #10
Gemak
Drives: 2014 Yaris,TRD sway bar, suspe
I have AT and followed the guides in this thread and now I have CC. Go for it, just be careful with the air bag
Gemak is offline   Reply With Quote
Old 07-29-2024, 11:53 PM   #11
CarpeDiem
Drives: 2008 Yaris Sedan
Hey guys, I got the kit today and installed the CC in a 2008 Yaris (no cruise light)...fast forward and I can't seem to get it to work. Did some troubleshooting over all connections (Pins are fully seated), checked the ground and the connection at the ECM all seem fine. When checking the voltage at D3 pin1 I have 13.3V, hold down the on/off switch and still 13.3V (not going to 0V). Could it be possible that the offshore Amazon stalk is bad out of the box? Any thoughts?
Thanks in advance
CarpeDiem is offline   Reply With Quote
Old 10-13-2024, 06:17 PM   #12
Cris_co1221
Drives: 2007 Yaris 3dr
Thanks in advance
I am having the same issue, but a 2007 3dr manual. I have all oem parts but cc not working, and same voltage issue when depressing the on/off switch.
Cris_co1221 is offline   Reply With Quote
Old 10-19-2024, 06:41 PM   #13
Cris_co1221
My issue was pin #2 on d3 wasn’t fully inserted (ground wire), got that hooked up and am fine now.
Old 08-10-2024, 09:47 PM   #14
Markwelch415
Drives: 08 hatchback
Does anyone have a link for the instructions? I can't seem to get this one to work. Thanks! In very interested in doing this!
Markwelch415 is offline   Reply With Quote
Old 08-11-2024, 06:58 PM   #15
thetut
Drives: 2007 4dr sedan
Read post #152
thetut is offline   Reply With Quote
Old 08-12-2024, 06:16 AM   #16
BLH
Drives: 2007 Yaris Sedan
It is in post #162
BLH is offline   Reply With Quote
Old 06-01-2025, 10:19 PM   #17
scott10301
Drives: 2007 3dr Hatchback
Just did the install today and no luck. I have a 2007 with no indicator light and want to troubleshoot to see if I'm at least the switch to the ECM is working.
How do I troubleshoot this? I saw that some are mentioning that they're testing voltage while depressing the on/off switch. Are you removing the pin from the D3 connector and then using a multimeter to test? I'm not sure how else that would be done. I did pull the pin and checked and am getting 13.3 volts whether I press the on/off button or not.
scott10301 is offline   Reply With Quote
Old 08-11-2025, 05:20 PM   #18
scott10301
Update - I found the issue. The splice connector under the hood was not set up properly. Set it up correctly and all is working well.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
