Old 04-21-2011, 05:21 PM   #1
YarTrek
Aygo Crazy
YarTrek's Avatar
Drives: '08 Blazing Blue LB MT
Power window failure
Anybody encounter a power window problem on their Yaris yet?
My passenger side power window is dead on my 2008 3-door. Neither switch works, no power at all getting to the passenger side window, driver side works fine so prob not a fuse(?) Comp warranty still in effect for another 2 months.
YarTrek is offline   Reply With Quote
Old 04-21-2011, 05:56 PM   #2
crank windows ftw
Old 04-21-2011, 11:31 PM   #3
YarTrek
Aygo Crazy
YarTrek's Avatar
I wanted crank windows but if I wanted the side curtain airbags I had to get the power package (in '08 safety was optional). The 60/40 split FOLD FLAT rear seat was also highly desired. I miss (so much) the days you could custom order options.
Old 04-22-2011, 02:05 AM   #4
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
probably just the switch, there is a DIY here on how to remove the door panel.
Red Horse is offline   Reply With Quote
Old 04-22-2011, 04:55 AM   #5
my passenger side's been dead for about 2 years now
Tried to troubleshoot it myself, seems to be the motor, as there is voltage going into it. Rarely ever need to use it so I never really bothered to get it fixed...
Old 04-23-2011, 10:50 PM   #6
YarTrek
Aygo Crazy
YarTrek's Avatar
Thanks for the opinions! Going in for service next week and will report.
Old 04-24-2011, 12:14 AM   #7
auxmike
auxmike's Avatar
I might start "excercising" my pass side wind once a day.
Seems P/W motors drag and get real slow when you never use 'em...
Old 05-11-2011, 08:03 PM   #8
08YARI
Drives: 2008 Yaris 2D HB
let me know what you find out. My passenger side window started doing the exact same thing today. I have a 2008 3d yaris.
08YARI is offline   Reply With Quote
Old 05-24-2011, 01:41 PM   #9
petyanca
Drives: 09 LB, 3 door, auto
same problem here, did you get diagnosis on yours ?
petyanca is offline   Reply With Quote
Old 11-24-2013, 05:13 PM   #10
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Unhappy I Just Got to Join This Club, Too
Was changing out my wheels to get into winter mode... and yep, I'm in the same boat...
Switch feels the same, just don't hear anything over at the passenger door (vs. being able to hear the power window motor if, say the window was frozen shut). I think the last time I used it was maybe a week or two ago. And they both get used about equally as I'm always popping them open to use the vent visors while parked in the summer.
Where's the first place to look to figure out if I can fix it?
Old 11-24-2013, 08:21 PM   #11
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Might sound archaic, but try slamming close hard the door with the "dead" motor. Other than that, you can take the door panel off, and test for power at the motor with a test light.
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 11-24-2013, 10:33 PM   #12
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Might sound archaic, but try slamming close hard the door with the "dead" motor. ...
No dice there...
... Other than that, you can take the door panel off, and test for power at the motor with a test light.
Well, at least I know what Yaris project I need to work on this spring!
Old 11-25-2013, 12:49 AM   #13
nookandcrannycar
Someone at Nissan was listening. One can get the 2014 Versa Note with hand crank windows and a 60/40 seat. Are you listening Toyota?
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 10:03 PM
Smoke from power window today....... aden General Yaris / Vitz Discussion 13 04-23-2011 11:48 PM
Power Window Switches Stoln Australia 5 11-07-2008 10:02 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 07:27 PM
