Old 05-01-2011, 12:50 PM   #2
TOLMACH
Drives: soarer
Sounds like LPF (low pass filter) is engaged somewhere: either at the head unit or at the aplifier that "cancells" everything above the cross-over point (usually 40-120 Hz)
Check the crossover panel at your amp .. if no cause is found, check HU settings | correct RCA pair at the HU back
Re hi-level speaker cables from the HU to the speaker - why would you connect them if you have amp? No need to disconnect , but make sure the internal amps of te HU are switched off (if your HU allows it, check seetings) to save power and prevent HU "heating"
Speakers in rear panels - 3dr BurningSky In Car Entertainment + Electronics (audio / video / alarm) 1 09-07-2010 03:33 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
