![]() Drives: 07' Yaris Hatch Join Date: Jun 2011
Will these fit?
Hey does anyone know if the 14" Honda HX wheels will fit on our cars without issues. I would assume they would but Just thought I'd ask to see if anyone is already running them.
will depend on spoke design and offset....have some pics?
I presume this is the Honda wheel you're talking about. I don't recall seeing any yarisworld member with these wheels. Unless someone can give you a definitive answer, I guess you'll just have to test fit.
I need more stars
Drives: Liftback Join Date: Jun 2009
Had these on my old civic. They are 4x100 and about 45 offset. Should fit on the yaris..
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
May have to run small (5mm) spacers, but I'd say there's a very good possibility they'll fit.
I ran 14" CRX SI wheels with 5mm spacers and they cleared. |
2ZR swap. DO IT! Ask how!
#8 | |
I believe these wheels are manfactured by Enkei, and I've not heard of any issue with 14" Enkei wheels to clearing the calipers. This does however remain as the one and only potential fitment issue.
The 4x100 Hondas are 56.1mm for the center bore (same as Mini Cooper) versus the 54.1mm for the Yaris. It is really hard to find hubcentric rings for that small of a difference, but with the proper tapered lug nuts you can run lugcentric.
This is a great reference for bore and lug pattern: http://adaptitusa.com/referencebook.htm And, this is the only place where I have seen off the shelf 54.1 to 56.1 hubcentric rings: http://www.hubcentric-rings.com/size-56.1-54.1/
at a 45 offset...id wager you'll need 5mm spacers to clear the calipers
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Test drove Rio5, Fit, and Yaris all today | kmf123kmf | New YARIS Purchase Forum | 16 | 10-02-2009 07:48 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 07:40 AM |
