Old 05-09-2006, 09:27 PM   #1
BrownNBubbly
Drives: MX-3 red
no tach= problem for newb?
alright, if there is no tach (liftback), would you be able to figure out when the car redlines? if i do actually get the car (under the hands of parents decision), this will be my first manual car. but since there is no tach, something tells me i may have a problem knowing when to shift.
yea i know you can feel/hear when to shift , but will a newb like me really know when? thanks for the info.
BrownNBubbly is offline   Reply With Quote
Old 05-09-2006, 09:38 PM   #2
evolutionist03
Drives: 2007 Toyota Yaris Hatchback
Send a message via AIM to evolutionist03 Send a message via MSN to evolutionist03 Send a message via Yahoo to evolutionist03
You will, specially on an engine of such size! The sound will be the best help!
evolutionist03 is offline   Reply With Quote
Old 05-09-2006, 10:13 PM   #3
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
You will know, don't worry about it. Just don't drive it like a maniac during break-in (*cough*) and drive it so your shifts to 2nd are smooth. The engine isn't going to blow up if you redline every once and a while.
Idjiit is offline   Reply With Quote
Old 05-11-2006, 07:47 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I also agree that you will be fine. Just listen to the engine and the way the car feels.
Colin Chapman disciple
Old 05-12-2006, 07:54 AM   #5
boxerboy
Drives: WRX ,Tacoma and Yaris
You will be fine, you will learn quickly.
boxerboy is offline   Reply With Quote
Old 05-12-2006, 10:38 PM   #6
BrownNBubbly
Drives: MX-3 red
thats good to know that it wouldn't be a problem, thanks! now the only thing standing in the way of me getting a yaris is the fact that i just got a car a year ago. x.x
Yaris rules! even if i dont get one!
Old 05-17-2006, 12:34 PM   #7
Calidrifter
Drives: 1997 Nissan 240sx
If you read the owners manual it will tell you what mph to shift at sometimes, well at least it did in my 240sx's owners manual.
Calidrifter is offline   Reply With Quote
Old 05-17-2006, 02:51 PM   #8
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
My Yaris manual (Canadian) tells you in MPH and km/h the "ideal" shift speeds.
I think they were (in km/h)
2nd - 24 km/h
3rd - 40 km/h
4th - 64 km/h
5th - 74 km/h
(^^ thats for gearing up)
Gearing down from 5th to 1st, they wer
4th - 65 km/h
3th - 65 km/h
2nd - 40 km/h
1st - 24 km/h
(^^ Yea, gearing out of 5th and 4th was the exact same speed... first manual, so I dunno if thats usual or not... because its like u dont even need to hit 4th if you're gonna gear down sequentially...)
Im almost positive those #s are right, or very close! ... id have to double check though
Jem
Jem_hadar is offline   Reply With Quote
Old 05-17-2006, 02:59 PM   #9
derekjd
Drives: Yaris Liftback 07
converted from above
Here in mph:
UP
2nd --- 14.913599999999999
3rd --- 24.855999999999998
4th --- 39.7696
5th --- 45.983599999999996
DOWN
1st --- 14.913599999999999
2nd --- 24.855999999999998
3rd --- 40.391
4th --- 40.391
derekjd is offline   Reply With Quote
Old 05-17-2006, 03:05 PM   #10
Idjiit
5 Stars, Bitches
Originally Posted by derekjd
Here in mph:
UP
4th --- 39.7696
DOWN
3rd --- 40.391
4th --- 40.391
Bwaahahahhahhaha. Yeah, okay, whatever. I typically shift into 3rd going about 55mph. ;)
Old 05-17-2006, 03:16 PM   #11
Jem_hadar
MORDSITH
Jem_hadar's Avatar
I dont follow those speeds to a T either, I listen to the engine and check the RPMS...
usually, im in 2nd aroud 20 km/h, 3rd at 40km/h, 4th at 60km/h and into 5th around 80k/km
Old 05-17-2006, 10:41 PM   #12
Calidrifter
Doesn't everyone?
Old 05-17-2006, 01:48 PM   #13
Chickon
Drives: Mazda RX-8
That might not be a pretty good idea unless you're very used to Manual Shifting.
Most engine can handle higher than factory pre-set redline limit at least 1.5K Rpm. but redlining every so often is not that good idea. Especially 1NFZ engine.
Me for example, I dont even look at the Tacho in my 8 most of the time, Unless I have to go fast, plus my 8(most cars would) will *beep* when I reach 9K redline *but I still upshift around 9.5K*.
Just follow the manual and upshift when it hits the speed. and install a Tacho meter asap.
Chickon is offline   Reply With Quote
Old 05-17-2006, 02:46 PM   #14
riceboy
Drives: icebox
no real need for tach.. unless you're running the car hard... you can pretty much tell by sound...
riceboy is offline   Reply With Quote
Old 05-17-2006, 04:52 PM   #15
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Those numbers are to achieve ideal fuel economy, I believe.
Old 05-17-2006, 10:44 PM   #16
Calidrifter
Which means that its at about 3k on the RPM so double the amount for performance.
Old 05-18-2006, 12:00 PM   #17
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Aye, it states as much in the manual.
The best compromise between fuel efficiency and power I think it was ;)
Old 05-18-2006, 10:02 AM   #18
why?
why?'s Avatar
Drives: Yaris LB
No. lol.
