Old 01-26-2012, 01:58 PM   #11
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Derick...
Spurring you on with some blurry skunk-works pictures:
^Envision the two big amps in the enclosure. The enclosure's edges are rounded out with short hair or bondo to curve the enclosure's sharp edges. The enclosure is painted a flat white (to contrast with the black of the amps). The cover has these cutout shapes as you see here so you can see down into the enclosure as well as a roundover on the cuts to make the shapes more gentle to the eyes. Now, line the upper sides of the enclosure with white LEDs...that will make the flat white paint glow. That IMHO is a sweet little amp enclosure. The top cover to the enclosure will be carpeted (could be vinyl or painted but it wouldn't match the OEM look) to match the OEM trunk look.
^This is the placement of the amplifiers if you'll recall. Note that the right side of the trunk will be flat like the left soon.
^Mounting points and wiring paths.
^More mounting points for the thread serts.
^I'll be placing the third amplifier on the top of the enclosure cover and working some of the neat shapes around it. With that third amp on top, I'll have a glow coming from under it, you'll look in and WHOA! Big amps! Just wait and see what's coming next! I'm going to be finishing the trunk up and then starting on the interrim sub enclosure until Scott gives me the Legatia woofer coming out later this year to test under the glove box area.
Wow, can't wait!
one of my LOWS stop working got to trouble shut tonight
D.
CLA 250, 4MATIC
