Old 02-08-2012, 05:38 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
hid install help (ground)
so i got my ddm tuning HID (slim ballast) there's a positive wire and two negatives. I connected the positive and negative to the battery terminals, and then the other negative i am trying to figure out where to connect. i think it is for ground, i tried tapping to a bolt it works both lights come on but the bolt is so tight it's not possible for me to unscrew it, i don't think it is made for ground. Which bolt is made for ground? right now only 1 side of the hid comes on. thanks!
caineroad is offline   Reply With Quote
Old 02-08-2012, 06:23 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
So when you ground this wire your lights work normally? You can turn them on and off?
Old 02-08-2012, 06:26 PM   #3
caineroad
caineroad's Avatar
yes that's right!
Old 02-08-2012, 06:28 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You can really ground it on anything in the engine bay. Find a bolt that you CAN unscrew and use that.
Old 02-08-2012, 06:39 PM   #5
caineroad
caineroad's Avatar
thats the thing.. i can't really unscrew any of the bolts lol... mainly the placement of them are awkward, couldn't get my wrench to work or it's too far in the back couldn't get the leverage, is there anyway i can just stick it on top of the bolt? there are not many bolts honestly i can choose from...:(
Old 02-08-2012, 07:00 PM   #6
SineWave
Drives: Gen3 Yaris ZR Manual
Connect both negatives together on the battery negative.
SineWave is offline   Reply With Quote
Old 02-08-2012, 07:30 PM   #7
yaris2010RS
yaris2010RS's Avatar
man their are lots and lots of bolts in the engine bay......
my passanger side ground it on the engine itself
if u jsut cant seem to get it there are quite a few GTA members around here im sure some would be willing to meet and help
Old 02-08-2012, 07:46 PM   #8
caineroad
caineroad's Avatar
i'll give the engine a try!
Old 02-08-2012, 07:46 PM   #9
caineroad
caineroad's Avatar
that leaves with no ground, don't know what will happen
Old 02-08-2012, 09:14 PM   #10
caineroad
caineroad's Avatar
thanks guys, able to unscrew the engine nut, wohoo I'm going out to test my HIDs!
Old 02-08-2012, 09:17 PM   #11
SAV912
Pirate Yaaaaris
SAV912's Avatar
There should be a bolt on the passenger side strut tower behind the headlights that you can use as a chassis ground. That's where mine is. It also holds on my relay box just fine. Sorry it isn't super detailed but I'm at work and just went out and shot it with my phone. Hope this helps.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 02-08-2012, 09:33 PM   #12
SineWave
battery negative is ground/earth
Old 02-08-2012, 10:28 PM   #13
caineroad
caineroad's Avatar
-C
thanks! there is a hole but no bolt in my case!
Old 02-09-2012, 12:40 AM   #14
SAV912
Pirate Yaaaaris
SAV912's Avatar
Should be two holes. One directly above another. There are matching holes on the strut tower on the driver's side that should have battery/ECU grounds attached to it.
I'm not sure on the size bolt that fits in there, but it seemed to be a common size and should be available at your local Home Depot or equivalent hardware store. I'd feel much better using that location rather than grounding directly on the engine. The engine moves. The strut tower, unless you get in a huge crash, doesn't.
-C
Georgia Bulldogs!
Old 02-09-2012, 02:15 AM   #15
caineroad
caineroad's Avatar
-C
definitely! thanks!
Old 02-09-2012, 04:10 AM   #16
SAV912
Pirate Yaaaaris
SAV912's Avatar
definitely! thanks!
No problem. If I get a minute tomorrow, I'll see if I can take that bolt out and give you a rough idea of what size you might need to look for.
-C
Georgia Bulldogs!
Old 02-09-2012, 02:29 PM   #17
caineroad
caineroad's Avatar
sounds good!
Old 02-09-2012, 10:19 PM   #18
caineroad
caineroad's Avatar
does anyone know why my hids will only turn on after a few tries switching the light on?
it always takes the second attempt for the lights to come on
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
How to choose and install HID on FOG light charleschia1986 Cosmetic Modifications (Exterior/Interior) 18 12-20-2010 10:45 PM
HID Lights Install ? k3nn4 Australia 30 02-07-2009 09:42 PM
