Old 03-17-2012, 11:55 AM   #1
BlueBreeze
Drives: Yaris Sol Premium
My Yaris does not detect my USB
I have a Sansdisk Cruzer Blade 32GB.
However, the Yaris is not able to detect it.
Does anybody has a similar problem and willing to share your solutions?
Thank you!
BlueBreeze is offline   Reply With Quote
Old 03-17-2012, 12:08 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i think we need more info from you. Please be more specific as in what are you plugging it into, what are you trying to use it for, what model you have, what is stock or not, etc.
Colin Chapman disciple
Old 03-17-2012, 12:18 PM   #3
skuzzlebutt5
Drives: '12 Yaris SE Classic Silver AT
i think BlueBreeze is talking about the usb interface inside the glove compartment of the '12 yaris...
i think...
skuzzlebutt5 is offline   Reply With Quote
Old 03-17-2012, 04:40 PM   #4
BlueBreeze
Yes, I am referring to the USB interface in the glove compartment of the New Yaris (2012).
I have formatted the 32GB Sansdisk Cruzer Blade in FAT 32 format, and loaded it with MP3s. It can be detected on every PC except in the car.
Would you have any ideas what went wrong? Thank you!
Old 03-17-2012, 04:45 PM   #5
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
fat32 file format could be your problem right there. it might need to be reformatted back to ntfs . i know only certain systems recognize fat32. ps3,xbox, some computers etc..
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 04-06-2013, 04:11 PM   #6
canjobil
Drives: canjobil
Thank you!
I have the same problem. Did you resolve problem or not? I used 4GB. I try both format fat32 nad ntfs but it does not help me? Any other sugestions?
canjobil is offline   Reply With Quote
Old 04-06-2013, 04:39 PM   #7
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
It says in the manual to use FAT32 or FAT16.
Might just be that specific device, have you tried another thumb drive or iPod?
Old 04-06-2013, 05:39 PM   #8
nookandcrannycar
I'm just guessing, but the deck in your car might have the capacity to read an SD card, but not an SDHC card. I was recently trying to upload a pic for Hershey to view and one of my computers I was using (running Windows 7 Home Premium) wasn't recognizing the card. I did some research and found that the card reader might be the issue. I have 4 external card readers of various vintages and I then examined all of them. 2 are marked with SDHC as one of the acceptable formats and 2 do not list SDHC. The card reader I was having trouble with re recognizing the card was one of the 2 that did not list SDHC. I switched to one of the SDHC marked card readers and the same computer instantly recognized the previously unrecognized card. The card in question that I was using is a 16GB card.
edit: Ugh, I should have read more of the posts before posting. IF canjobil and the OP have the same head unit, then my suggestion above is not likely to be correct. I think Why? is right, we need to know which head unit the OP has in order to give the most constructive suggestions.
Old 04-06-2013, 05:54 PM   #9
nookandcrannycar
Originally Posted by jpmck03 View Post
Attachment 50384
But the Swiss (CHDM? ) head unit offerings might be different from USDM (and thus have different manuals).
Old 04-07-2013, 10:35 AM   #10
HowlingKing
Drives: Integra DC5R, Yaris ZR
Check out the 2nd dot point in the box on the right on jpmkc's post.
Cannot connect usb storage device.
HowlingKing is offline   Reply With Quote
Old 04-07-2013, 11:19 AM   #11
why?
why?'s Avatar
Drives: Yaris LB
Indeed. The number of different head units Toyota uses is staggering, and they are all different. The easiest way to figure out which one is in your car is to take it out and read it from the top. This is surprisingly easy to do in the Yaris.
Except jpmkc's post is probably for USDM, which will almost definitely differ from everywhere else in the world.
Old 04-07-2013, 03:22 PM   #12
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
VIA USB HUB!!
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 04-08-2013, 08:24 PM   #13
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
As an old guy like me, didn't even know it was possible.
screenprintr is offline   Reply With Quote
Old 04-08-2013, 08:39 PM   #14
jayeh
Drives: '08 Yaris LB
Pretty much any computer will recognize fat/fat 32
jayeh is offline   Reply With Quote
Old 04-08-2013, 08:41 PM   #15
screenprintr
Fat 32 is old technology. Didn't realize it was still around.
Old 04-08-2013, 09:24 PM   #16
Sandisk devices have a weird thing where they can operate in two modes (MSC or MTP). Try checking what mode it is currently setup for and trying the opposite. I had a similar issue with a Sandisk Sansa that one of my kids has.
http://kb.sandisk.com/app/answers/de...20mtp%20cruzer
Old 04-10-2013, 01:02 PM   #17
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
My Cruzer Edge 8GB works fine in my NA 2013 L model.
Amdkt7 is offline   Reply With Quote
Old 04-10-2013, 04:36 PM   #18
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I had no idea they actually finally put USB interfaces in...that is pretty cool. Are you sure that it isn't isn't partitioned?
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
