Old 04-10-2012, 07:39 PM   #5
09sedan
Drives: 2009 yaris sedan
Originally Posted by Em_ View Post
tire pressure should be 32PSI front and back
air filter ...dealer
for gear oil i would say 2 years or 50 000km and suggest RedLine gl-4 75w-90
for your Oil filter, Mobil 1 oil filters, AMSOIL oil filters or Purolator PureONE filters are the top best in the market, second to those is the dealer filter, stay away from fram filters.
depending on the tire as well, some tires might require a few psi higher then 32, check your tire make and model, if still worried about tire psi , contact the manufacturer of the tire (email or phone call usually) and they will give you a sure answer)..
for gear oil im not 100% sure, i have an automatic, i would only use toyota fluids except for engine oil
09sedan is offline   Reply With Quote
gearbox, maintenance, oil change, oil filter
new car maintenance mr_miles DIY / Maintenance / Service 4 10-23-2011 04:46 AM
Zefoxe - Photo Scavenger Hunt Zefoxe Photo-Video-Media Gallery 0 03-02-2009 10:23 PM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 06:13 AM
