![]() Drives: yaris 2912 Join Date: Jul 2012
Need help on 16x8'' rims on yaris 2011
Hi, i am planning to get this rims on size F16x8'' offset 30 and R16x9 offset 15. My ??? is will it fit nicely on yaris ? 2nd,and if i am going to lower by 1.5'' will it hit the fender ? And my last ??? is what tire size should i get ?
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
the front should be okay if you add the camber bolt, the rear is a little tricky. I think you can add the EZ shim, camber it 2* and you'll be fine. Im using 17x8.25 +25 all around and since I have the rear disc conversion, can't add that ez shim , so my rear wheels are poke out a little.
http://www.yarisworld.com/forums/showthread.php?t=40482 |
#3 | |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
I'm running 15x9 on the rear with 205/50 tires lowered about 3" and only rub with full tank of gas and 3 people in the car . Also have about -3 camber shims in the back. You'll need to run 195 wide tires max with the low offset
Garm is permanently high because he is the king of smokin' deals! |
やりすぎだ~
^ must post pic of 15x9 on car! NOW!
やりすぎだ~
Thanks! Wow. They fit good!
| 8 Questions About the 2011 Yaris 5 Door Liftback (HELP) | Pacquiao | General Yaris / Vitz Discussion | 5 | 06-09-2011 02:30 PM |
| New Toyota Yaris 2011 Spy Photos !!! | orheen | General Yaris / Vitz Discussion | 35 | 11-24-2009 08:08 PM |
