Old 08-20-2012, 10:53 PM   #37
carolinablue
Drives: 2012
The new style tail lights have personality and they are unique and distinquish the 2012 Yaris from other small Japanese designed and engineered automobiles.
carolinablue is offline   Reply With Quote
Old 08-21-2012, 12:18 AM   #38
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by 12 yaris View Post
So my Yaris looks like a Versa??????????
I'm still hoping the 2012 model will grow on me. Afterall, it's a Toyota... and what else would I buy but a Toyota! However, I think the 2012 4-door model with that hideous A-shaped C-pillar looks like a Versa from the side. So, I'd have to opt for the 3-door version once again. Unfortunately, from the rear the 2012 looks like a Matrix, and from the front it looks like a Prius with a bad nose job.
Old 08-21-2012, 02:34 AM   #39
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by carolinablue View Post
Tail lights with big circular centers? They certainly are odd looking! The lines in no way match the lines of the rest of the car.
Ok... we agree that we disagree.
Old 08-21-2012, 04:07 AM   #40
joshthorsc
Drives: 2012 Yaris SE 5spd
So far I hate the single windshield wiper and the door panels and can get scruffed so easily.
2013 Tundra CM Rock Warrior
1991 MR2 Turbo
2012 Yaris SE 5spd...Daily Driver
joshthorsc is offline   Reply With Quote
Old 08-21-2012, 09:03 AM   #41
matti
Drives: 2017 Yaris L (5sp manual)
I recently posted a question in regard to the scuffing of the door panel plastic. Someone recommended Turtle Wax F21 protectant as a way to protect from the scuffs. I put it on this weekend and it really helped a lot. It was about $5 at my local auto supply store.
On my 2012 2-door, every time I shut the driver's side door, I think the glass slides down just a bit and I can hear it rattle. That bugs me a bit.
FWIW, I LOVE the design of the tail lights.
matti is offline   Reply With Quote
Old 08-21-2012, 09:16 AM   #42
muffin_top
Drives: 2012 Yaris SE 5MT
The door shouldn't make any noises when closed, take it in and have the regulator bolts checked.
muffin_top is offline   Reply With Quote
Old 08-21-2012, 09:49 AM   #43
matti
I have hand-crank windows: does that make a difference? When I shut the door, I can hear the glass rattling slightly. After shutting the door, I can see that the hand crank has rotated slightly, allowing the glass to slide down just a bit.
Old 08-21-2012, 10:53 PM   #44
carolinablue
Drives: 2012
It should not do that. Contact your dealer, you are under warraanty, it is free.
Old 08-22-2012, 08:32 PM   #45
Chuck G
Drives: 2010 Yaris Sedan
I'm going through the exact same thing!
Old 08-28-2012, 01:29 PM   #46
carolinablue
Drives: 2012
It takes a couple months, but the car grows on you..............
Old 11-21-2012, 01:55 PM   #47
matti
Hi there. Just wanted to give a quick update on my driver's side window (hand crank) rattle/movement in the 2012 Yaris L. I had it in for the 5k service today and they checked it out. They said they couldn't really see what was wrong, but they did order a new window regulator, which I'll get installed in about two weeks. I appreciate my dealer's good service so far.
Old 11-21-2012, 09:32 PM   #48
shrek
Drives: 2012 5dr Manual Yaris
My biggest gripe is with the stereo unit (non Nav). I play my music from the USB, but every time I turn the car off, it goes back to folder 1, song 1. It has no memory and now I hate Red Hot Chili Peppers - By the way. Screw you toyota.
shrek is offline   Reply With Quote
Old 11-29-2012, 12:29 PM   #49
nookandcrannycar
Some 2012 owners have posted that they feel the single blade windshield wiper on the 2012 doesn't do a good enough (safe enough?) job of maintaining visibility during a hard rain. Have you found that to be the case?
Old 11-29-2012, 12:33 PM   #50
nookandcrannycar
I like the A-shaped C-pillar, and especially the fact that that the 5-door no longer has that small window in that area that can be (more easily and quietly than a big window) be broken by a thief.
Old 12-26-2012, 06:16 PM   #51
Superfly
Makin' it rain
Superfly's Avatar
Drives: 2012 Silver Yaris LE
General gripe about all new cars including the Yaris: the A pillars are getting huge and the blind spot looking out forward and left is growing large enough now that I am forced to work my head around during big curves on the roads so I can maintain a good vantage point.
Biggest complaint about the 2012 Yaris: location of the USB/AUX inputs. Seriously Toyota, why the back of the glove box? What a major pain to deal with especially if I am not going to leave my iPod plugged in all the time.
Superfly is offline   Reply With Quote
Old 12-26-2012, 09:09 PM   #52
NJ Drive
I've put 15,200 miles on my car since I purchased it in March of this year.
I don't really have much to complain about other than the fat A-pillars as mentioned above... and the lack of an LSD.
NJ Drive is offline   Reply With Quote
Old 12-27-2012, 07:55 PM   #53
GTBaker
GTBaker's Avatar
Drives: 2012 Yaris LE
My biggest gripe is the washer for the front mono wiper. It only sprays 1/2 way up the windshield.
For now I fixed it by jamming one of those straws you get with WD-40. It helped a lot but will get the dealer to look at it when I bring it in for the oil change.
GTBaker is offline   Reply With Quote
Old 12-27-2012, 09:44 PM   #54
NJ Drive
If you look closely at the sprayer nozzle, there is a very small spherical-shaped jet. You are capable of moving it with a ball-point pen to help fine tune the spray onto the windshield. Be forewarned that the spray pattern is a lot different at speed than at rest, so a little trial and error is needed.
2012 Toyota Yaris alarm tonyc1234 DIY / Maintenance / Service 0 05-04-2012 04:29 AM
Has anyone put a rear antiswaybar on a 2012 Yaris? carolinablue Third Gen Yaris General Discussion 16 04-26-2012 09:41 PM
2012 Yaris Accessory Catalog (UK) CTScott Third Gen Yaris General Discussion 13 02-06-2012 02:36 AM
