Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 12-04-2012, 02:32 PM   #10
scotmech
Drives: Toyota Yaris Verso 2004 T3
As my car is a … Toyota Yaris Verso 2004 1.3 RHD Manual Transmission … and the instructions are for a Toyota Echo LHD …
The wiring colours are different and the Instructions are not too easy to follow …
There are 6 main wires to connect … Just the Grey Wire left to the VSS Sensor to connect …
Black Earth Wire (Done)
2 on the Brake Switch (Done)
Accessory feed at the fuse Panel (Done)
VSS (Vehicle Speed Sensor) Grey Wire
Tach Sensor Dark Blue Wire (Not Necessary as it is Manual Transmission)
Not sure what this means …
Grey Wire Attachment for VSS Signal … Location 7 – Back of Knee Panel 2 connector from top …
Data Link Connector has 7 wires in Positions …
4 … White/Black
5 … Brown
7 … Purple or Violet
9 … Green/Black
13 … Pink/Black
15 … Pink
16 … Brown/Black
Can you explain exactly where this connection is made ...
Can I connect the VSS Grey Wire at the Instrument Panel or the DLC ...
scotmech is offline   Reply With Quote
Someone know what parts I need to chang to get automatic klima control in my Yaris? Per Kristian Cosmetic Modifications (Exterior/Interior) 10 04-07-2011 12:51 PM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
