0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
Nope no contact aside from the muffler hitting the heatshield at idle making a slight rattle noise. The noise in and of itself isn't from contact but mostly due to the location of the muffler. Behind the header is a cat, muffler, and turndown or side exhaust depending on how I want to run it. The muffler is tubing diameter is 2.25" and the tubing is perforated its a magnaflow. I've had the same behavior with all the mufflers I've used the small and large ones so Idk.
The exhaust is much louder at lower rpms and high load because its a low frequency and when the motor is screaming its a higher frequency. I think its partially due to how the cam timing behaves are high load low engine speed since there is a ton of overlap. |
| OBX Header | Galavoxx | Performance Modifications | 3 | 04-20-2007 11:36 AM |
| Megan Header Advice | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 1 | 02-20-2007 07:22 PM |
| Weapon-R Header (4-2-1) | CASTREX | Performance Modifications | 28 | 02-19-2007 01:57 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
