#235 | |
play every day
![]() You want the flow to be compatable with the larger throttle body anyways. |
#236 |
I got PM's that the thread has become confusing, and I can't prune it, so.....
For those following along, please note that posts from #231 on (Silver Streak) refer to swapping a 1ZZ throttle body onto a STOCK manifold, and are not about the MICRO IMAGE manifold. Our manifold comes with the O-ring, is a direct bolt-on, and requires no modifications to use either a 1ZZ throttle body or your stock 1NZ throttle body.
#237 |
Form>Function
awesome ^^
sorry to get off topic |
#238 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Awesome! I'm so excited to see the new version of the manifold. I've already got my information in and am on the wait list. I can't wait to get this and install it with my 1ZZ throttle body.
#239 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
now to get Garm to confirm the intake kit that comes with the 1zz throttle body and a set of 1zz injectors. hint hint...
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#240 |
Why would you need 1zz injectors? I mean, I understand that they are a larger injector, but unless you are going turbocharged/supercharged, what's the point? Seems like it would be a bit overkill for NA.
#241 |
Form>Function
Not necessarily, a large TB and upgraded manifold will lean out the mixture. I'm sure the maf will see more air coming in and increase the fuel delivery but if the stock injectors can't pump anymore, then the 1zz should meet those needs. More air + more fuel = more explosions = more power.
#242 |
^ I don't see this manifold + 1ZZ TB requiring larger injectors.
Dynos will tell, but it certainly doesn't need them with the stock TB - as shown on the dyno.
#243 |
Not always. I've dyno-tuned two Hondas I've owned in the past with VAFCs and wide-band, both with many bolt-on mods and larger throttle bodies. Naturally aspirated, with stock injectors, EVERY TIME I made power by reducing the fuel injector pulse from stock. You'd be surprised what the stock injectors are capable of, every time I've put a car on a dyno with a wide-band o2, the car was running rich and I ended up taking away fuel to make power. In the case of my H22A-swapped Civic, I made 9 hp and 10 tq at the wheels with just a VAFC and some dyno time. The fuel and air mixtures need to be in balance, too much of either one isn't a good thing.
More air + balanced fuel = more power More air + too much fuel = less power, lower mpg |
#244 |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
anyone get theirs yet?
pictures? / install impressions? sound? / buttdyno? Will |
#245 |
Form>Function
not yet but I am dying waiting lol
mines in finishing right now |
#246 |
play every day
#247 |
Form>Function
well they only got 3 and mine is one of those and its actually being custom plated... I couldnt keep it a secret anymore lol so its taking a while
the other 2 may have shipped out already unless maybe garm is keeping one to put on his hatch |
#248 |
i really cant imagine the need for bigger injectors for this N/A setup. Your better off getting your car tuned.
#249 |
I've tried calling and emailing but don't have a date as to when I'm getting one shipped to me yet. I WANT so badly. When I do get one I'll be sure to post lots of pics and try and get it to a dyno after install.
#250 |
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
Forgive me for not wanting to read through 14 pages of posts....but is there any dyno data on this intake manifold to show the gains? thanks.
#251 |
Form>Function
Here you go
#252 | |
We now have five going out by Friday; I'm sure there will be some feedback by next week sometime.
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 02:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 07:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 12:58 PM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 09:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-14-2008 12:26 AM |
