Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
My new grille blocks for my sedan...
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Mr. 155 and climbing
reason for using?
Nice! Can hardly tell it's there.
fnkngrv, it makes winter/cold weather driving much better. Much shorter warm up times, and protects the rad from salt and stones. |
so wtb then?
Obsessed with 1.5L
Yes faster warmup and less aero drag from the air being slowed down going thru the rad. I normally would of ran a smaller opening but I figure this will work for now. My old xB my left over opening was about half of this.
やりすぎだ~
Looks great! I'm curious about engine temps. Blocking off both top and bottom inlets, does it ever get too hot? (overheat)
I run the lower completely blocked off and I never run into issue until about 5°C above freezing.
I have a mechanical temp gauge in the block, so I know the exact water temp. Normal with no block it runs at about 180-190°F. With the block it runs 190-210 on the hwy. But that's only after about 20-30min. If it gets any hotter I just turn the heater on and crack the windows and the temps come down. |
Obsessed with 1.5L
i havent hooked up my scangauge to verify temps yet. but i figured my xB was fine even during the summer with a smaller opening, then mine should be fine...especially now
i probably should actually install the scangauge in this car...
I've been running a full grill block in my cavalier for around 4 years now. I know, different car, different challenges. I started with the plexiglass cover though I will say it gets pretty scuffed over time. I painted my cover and did that for a while until I fiberglassed it off. the end product came out pretty well though youtube flamed me pretty hard over it.
Depending on how the car gets its cooling, blocking off the grill doesn't matter at all. My cavalier actually got 90% of its cooling from underneath. Not sure how the airflow in the yaris works yet. It does look good and very incognito |
Obsessed with 1.5L
Its got a factory tray under the bumper. So its sourcing all the cooling air from up front
Very nice .
![]() ![]() Drives: 07 hatchback Join Date: May 2012
I did a very similar thing except I used black aluminum which means it just looks like one big hole to me
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Nice! Aesthetically appealing!
Cheers! ![]()
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS ![]() Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
2007 Yaris Sedan Front Grille | Stacieee | Cosmetic Modifications (Exterior/Interior) | 1 | 05-29-2012 09:48 PM |
Is '09 & '10 yaris sedan grille compatible? | jizan | DIY / Maintenance / Service | 1 | 03-27-2012 01:40 PM |
09 sedan grille | Francos Yaris | General Yaris / Vitz Discussion | 17 | 11-23-2010 04:28 PM |
