Old 03-12-2013, 02:04 PM   #23
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
It's been 20 years since I ran out of gas, and it was on a sharp curve. Coasted around and it started back up. I nearly always run until almost on E, sometimes a bit longer. I don't know about the Yaris yet, but most cars seem to have around one gallon or more left when on E. That being said, if the weather is going to be bad I'm going to fill up so I don't get stuck somewhere out of gas.
It wastes gas to be carrying around a full tank all the time, and there is some concern about the fuel pump burning out when empty (I suspect that only happens when it cannot pick up any fuel, not because the tank is low). The pump is located at the top of the tank, if it had to be submersed it should be at the bottom of the tank.
Condensation will not cause the tank to rust. It has a rubber liner. Condensation can be a problem if you do not fill up all the way, or perhaps if you have a low tank for a very long time. So, always fill the tank all the way up, the air is pushed back out into the charcoal canister and then mixed with the air pulled into the engine (burns off gas vapors).
Best practice is to run to nearly empty (except when there is a chance of running out of gas, due to weather, or unknown distance to station), then fill it all the way up. As mention before, know how far you usually travel on a tank of gas, and use that information as well as the gas gauge.
I once had a battered old Dart ('63 I think). It had a leak in the tank, filling too full would result in it leaking. The gauge was screwed up too. As the tank emptied the needle slowly go down, but then would suddenly RISE! When that happened you had to get gas Now!
Amdkt7 is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 08:24 AM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 04:20 PM
SO I RAN OUT OF GAS THE OTHER DAY ROCKLAND TOYOTA General Yaris / Vitz Discussion 76 10-23-2008 02:02 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
