If you look at the bottom of the blower housing there are a couple of screws that mount the black part (which is the blower fan) to the bottom of the housing. You can remove those screws and pull it out, but it is not designed to be disassembled and lubricated. Replacing it is going to be your best option.
Do you have a cabin air filter installed, as not having one could definitely lead to premature failure of the blower motor?
| A/C Blower Dismantling? | Yaross | DIY / Maintenance / Service | 9 | 12-14-2011 03:56 AM |
| Why wont my fan blower work? | lucy7509 | DIY / Maintenance / Service | 4 | 08-09-2011 02:48 AM |
| 09 Yaris Heater blower problem | motoxxx3 | DIY / Maintenance / Service | 28 | 10-15-2010 05:45 AM |
| A/C blower resistor | ubear7 | DIY / Maintenance / Service | 1 | 08-08-2010 09:53 PM |
| dead mouse in my blower unit | beacon | DIY / Maintenance / Service | 20 | 11-25-2008 12:31 PM |
