Old 04-02-2013, 04:52 PM   #1
Originally Posted by skoya View Post
Ok Scott,here on this pic you can see these three transistors or whatever they are,seems to be burned.You can tell by their middle pins.I have isnpected them with ohmmeter,and the current flows on both sides instead of one.They are type MK 58.So when I turned the cluster on the other side,you can see clearly brown spots on this green pattern.Can you confirm that this could be the problem.You can see them right in the bottom middle section.
That could be the problem or at least part of it. On mine all six of the transistors in that area check out correctly with the ohmmeter. I believe the 58 is a date code, since mine are all MK 61 on one cluster and MK 68 on another.
Old 04-02-2013, 04:58 PM   #2
skoya
skoya's Avatar
Drives: Yaris 1.0L
Where can i buy these.Is there anything on ebay,or some another web page.
And i need some characteristics for this type.
skoya is offline   Reply With Quote
Old 04-02-2013, 05:12 PM   #3
I am not sure. The MK alone is not enough information.
Old 04-14-2013, 05:37 PM   #4
skoya
skoya's Avatar
Drives: Yaris 1.0L
Hey Scott,can you please help me with this transistor.I could not find nothing with this code MK 58.It has to be another name for it.
Old 04-14-2013, 06:37 PM   #5
The number is just the date code. Unfortunately the MK portion has not been enough for me to figure out exactly what it is either. The only thing I can think of at this point would be for me to remove them off of one of mine.
Old 04-15-2013, 07:53 PM   #6
skoya
skoya's Avatar
Drives: Yaris 1.0L
I would be very grateful if you can do this for me,that's if you don't need them anymore.I need three pieces.
Old 04-15-2013, 09:19 PM   #7
I have one of the right hand drive ones that I just use for harvesting parts, so I can definitely ship you the three. They are tiny enough to be able to ship in an envelope as a first class letter, so shipping would only be $2.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
