Old 06-02-2013, 09:59 PM   #1261
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
This is the next step... punch a hole to insert the bellmouth.
Hey Cranky,
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer.
There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate. I'll also be inserting three aluminum tubes where the blue dots are for the hoses, so they'll also need to be welded into place.
Old 06-03-2013, 06:03 AM   #1262
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by tooter View Post
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer. There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate.
Aah, that makes sense.
Curious-er and curious-er. This thing really is going to look alien when you're done!
Old 06-03-2013, 10:49 AM   #1263
tooter
play every day
tooter's Avatar
Yes. The hose fittings are the antennae!
The manifold will be a lot more compact because a hemisphere is the most volume efficient shape for a plenum. This will move the throttle body to the left which is closer to its original stock location.
I'm totally curious as to what the effect will be as there are no flat surfaces for the reflected pulses from the mouths of the runners to bounce off of. The entire inner surface of the plenum, including the 180 degree rounded bellmouth of the throttle body bore, is 100% curved.
I just gotta find out what will happen. And the sales of the tooter products have bought the freedom to explore...
Old 06-03-2013, 11:00 AM   #1264
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Very cool build!
JustDidIt is offline   Reply With Quote
Old 06-03-2013, 11:28 AM   #1265
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
<--this guy is a alien sponser lol
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-03-2013, 12:32 PM   #1266
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
does it look phallic for Garm yet? :P
Old 06-05-2013, 04:49 PM   #1267
10 Francis
Drives: 2010 Yaris S HB
subscribed
10 Francis is offline   Reply With Quote
Old 06-06-2013, 07:22 AM   #1268
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Is it welded together yet?
Old 06-06-2013, 10:16 AM   #1269
tooter
play every day
tooter's Avatar
Not yet. Right now I've got work piled up to the moon, so the manifold is on the back burner until I can get caught up.
Old 06-06-2013, 06:09 PM   #1270
Golddeenoh
Golddeenoh's Avatar
238,900 miles (384,400 km), that is a lot of work is it all paper work?
Old 06-06-2013, 07:22 PM   #1271
^ Plus the thing about being able to breathe.
Old 06-07-2013, 01:08 AM   #1272
tooter
play every day
tooter's Avatar
No, I don't do paper.
I'm a sparky.
Old 06-07-2013, 01:24 AM   #1273
tooter
play every day
tooter's Avatar
Hey Garm,
Injen sent out a good replacement tube, and the intake looks great!
It was late so I only got to run it to see if there would be a CEL. No light.
Old 06-07-2013, 11:03 AM   #1274
Looks great - I like the little shield.
Old 06-07-2013, 11:56 AM   #1275
tooter
play every day
tooter's Avatar
I do too.
The design is very simple and direct. It's a whopping 3 feet long and actually very quiet. It's also easy to move around if I start messing around with the intake manifold.
Check out the header. LCE makes a really neato design that folds a long tube header into exactly the same space as the stock header. It fits like a glove!
Old 06-07-2013, 12:47 PM   #1276
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
^^^ RE: "long tube header" - Please forgive this noob question, it really is a question and not a troll, but why does it matter the length of a pipe? Don't you want the exhaust to just get out via the back of your car rather than in the engine bay?
Old 06-07-2013, 01:35 PM   #1277
JustDidIt
JustDidIt's Avatar
Not my wording but makes sense:
Exhaust headers with equal length tubes have been shown to develop slightly more power on an open exhaust system, but not when hooked up to a street system with mufflers. Fact is, most street motors with shorty headers will produce the same power as they would with expensive equal length headers.
Equal length tubes can produce more power, but they have to be the right length for the specific motor at the RPM range where you want the power. What that means is lots of custom fabrication and dyno testing, which translates into lots of time and money.
For racing applications, the slight gain may justify the cost, but competition cars can be more easily built "around the engine" than street cars. When you're working within the confines of a given body style and chassis, with motor mounts, starter, steering linkage and accessories to think about, the way the headers fit become more important.
That's where the compact or "shorty" style header shines. You get a significant performance increase compared to stock exhaust manifolds, at an off-the-shelf price..
Old 06-07-2013, 01:37 PM   #1278
Remove your header and see how much power you lose with no exhaust at all. A LOT.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
