Old 08-23-2013, 05:28 PM   #5
jcboy
Drives: Sedan 07
Maybe it is due to headlight specifications? I'm not sure, but if everyone else is experiencing the same issue, then i would be inclined to think so.
The American system historically permitted a greater overall amount of light within the low beam, since the entire reflector and lens area is used, but at the same time, the American system has traditionally offered much less control over upward light that causes glare, and for that reason has been largely rejected outside the US.
In addition, the American system makes it difficult to create markedly different low and high beam light distributions. The high beam is usually a rough copy of the low beam, shifted slightly upward and leftward. The European system traditionally produced low beams containing less overall light, because only 60% of the reflector's surface area is used to create the low beam. However, low beam focus and glare control are easier to achieve. In addition, the lower 40% of the reflector and lens are reserved for high beam formation, which facilitates the optimisation of both low and high beams.
http://en.wikipedia.org/wiki/Headlamp
now if it's about HID and the focus, then i would say it's normal. HIDs have light all through the length of the bulb while H4 bulbs (our bulbs) have only the filament/light on the front portion of the bulb.
HTH
Headlamp question jmew0ng Cosmetic Modifications (Exterior/Interior) 4 05-15-2013 02:54 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
One filament in the headlamp bulb. ellenbetty General Yaris / Vitz Discussion 7 09-06-2009 01:30 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
