![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
LPG conversion on a 2009 Sedan
thinking about doing a LPG conversion on my 09 sedan, looking at the direct injection system they have now for gasoline engines, ( it will likely be a duel fuel setup where i can switch whenever i want between gas and LPG) still waiting on my quote from a shop in toronto, anyone else do a LPG conversion before?
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I would think one or the other, not both. Engines would have different needs, lpg compression comes to mind, then of course delivery methods.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
Usually you cannot do a conversion for cars before 2005 models. So what year is your model?
best buy vacuum cleaners |
^ his username is 09sedan! I've seen dual setups, but not on a Yaris.
Good luck with your project, post up your progress!
| 2009 yaris sedan s (ipod/aux) speaker change | cleargrip | DIY / Maintenance / Service | 4 | 10-30-2012 09:24 PM |
| new Yaris 2009 sedan, 1 month old - problems already? | rirakuma717 | DIY / Maintenance / Service | 10 | 04-13-2011 12:00 AM |
| lpg conversion | parkincake | Fuel Economy Forum | 3 | 12-02-2010 10:39 AM |
