Old 02-19-2014, 01:39 PM   #6
Originally Posted by weedelf View Post
Awesome and thanks. I actually found it very easily and got the fuse quickly replaced. The car was stuck at a friends and I was able to drive it home.
Only problem is, it blew again a few hours later. I replaced it again...and a few hours later, it blew again.
I think it's obvious there's something else going on here. Anything I can do? Or pretty much time to take it in?
That fuse powers the following things:
1. A/C Blower relay coil
2. Back-up lights
3. Alternator voltage regulator
4. Park/neutral switch
5. Dimer rheostat
6. Rear window defroster relay coil
7. Passenger set belt warning light
8. AT Shift lock ECU
9. Flasher relay
You should actually be able to isolate it to one of those functions by trying each one separately and seeing with which one it pops again.
one rear brake light don`t work yaris 2008 abou salou Canada 1 04-03-2012 12:38 PM
Does this "afterburner" work with the Yaris? Parmas Cosmetic Modifications (Exterior/Interior) 28 02-16-2009 12:28 PM
