Old 04-29-2015, 02:07 PM   #1
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Originally Posted by tmontague View Post
I give a little throttle to rev match when going from 1-2 and 2-3, this makes for a smoother shift and should decrease the wear on a clutch
My coworker thought he was doing this as well. He couldn't explain HOW it's rev matching, when UPshifting.
Revs DROP when going up through the gears.
Old 04-29-2015, 05:14 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It depends on how fast you change gears, as well as how fast your crankshaft winds down. If you have a lightweight crank pulley and/or flywheel, you will likely have to blip the throttle when upshifting as well.
Old 04-29-2015, 05:15 PM   #3
tmontague
tmontague's Avatar
Rev match is definitely not the right word (although I do that when shifting down all the time to save the clutch). I give a slight bit of gas when letting out the clutch from 1-2 and even less from 2-3 gear. It gets rid of the rough shift normally found in low gear shifts.
Feel free to chime in as to why giving no gas at all at low gear shifts causing a rough shift and giving gas smooths it out. I'm assuming it's the same reason why you need to give a bit of throttle going from stop to 1st. Due to the lag of a slow moving transmission and a faster moving engine. Giving it gas helps ease the connection between the two.
Riding the clutch in a yaris negev DIY / Maintenance / Service 23 07-19-2013 11:11 AM
possible clutch gone bad? DevilGirl DIY / Maintenance / Service 19 11-15-2012 06:29 AM
I make guitars. Not 56k friendly. anomoly40 Off-topic / Other Cars / Everything else Discussions 11 07-29-2012 03:52 PM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
