Drives: 2012 Yaris Join Date: May 2015
Yaris 2012 Electric Power Steering Warning Symbols
Hii.. I have bought used Toyota Yaris 2012 Automatic 1.3 L Car in Jan 2015.
Recently, by mistake, Light was on while car had been switched off. Resulted in its battery discharge. When I tried to plug Key and start car. It was showing few symbols, which I later discovered for Electric Power Steering Warning Symbols. Somehow, I started my car using Jumper and battery from other car. I took to change my battery. I discussed the mechanic, they said, the warning light will go off. Problem is that when I insert my key, then only it shows the Power Steering Warning symbols. When car is on, and is running, no more this warning symbol appears. Please share your experience if you have come across similar issues. |
Smoke 'em
Drives: toyota vitz 2011 Join Date: May 2015
Hi, Ezzie here. You got no problem there, trust me if the steering wheel light was on after the ignition, then you would have a had a serious problem. I have a 2011 Toyota Yaris and the sensors do light up when you rotate the key and take it upto the ignition mode. Just make sure it doesn't light up after the ignition.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
bulb check
All the bulbs light up when you first start your car to let you know that all your bulbs work. No worries
| Tags |
| electricpowersteering, eps warning, yaris2012 |
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
