Old 06-05-2015, 11:36 AM   #1
Yaris_Mac
Drives: Gas saver
15x8 +28 205/50 any clearance issue...
I should be fine clearing the fenders but anyone know if The tires will rub on the suspension? The car will be dropped on Tein STech. Thanks!
Yaris_Mac is offline   Reply With Quote
Old 06-05-2015, 12:02 PM   #2
Originally Posted by Yaris_Mac View Post
I should be fine clearing the fenders ... The car will be dropped on Tein STech.
Wrong!
Old 06-05-2015, 12:19 PM   #3
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Tires will not rub on the suspension however it will rub on the fenders because the tein s-techs are quite soft. You would either need to stretch your tires (run a narrower profile), put in more negative camber, use stiffer springs, or increase your ride height. I used to run a 15x7 +35 and 205/50 setup with s-techs and it rubbed quite a bit.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 06-05-2015, 12:23 PM   #4
15x8 +25
I think you are not interpreting offset correctly. The lower the number, the more outward the wheels sit. By questioning if you will rub on suspension leads me to believe you are thinking +28 will place the wheels further inward than the stock offset of +45.
Old 06-06-2015, 12:40 AM   #5
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I actually have a similar question. I plan on installing Tein S Techs one day on the original struts along with the original shocks. I'm currently running a 185/60/R15 set up with original steelees. I'm expecting about a 2" drop as a result of the softer springs, so do you think I'll be running into any clearance issues? Will I have to switch to a lower profile like a 205/50/R15?
Old 06-06-2015, 03:39 AM   #6
Yaris_Mac
Drives: Gas saver
Thank you.
Some yaris owners runs low offsets such as +20 with 15mm spacer in the rear... 190/45/15 tires (low profile) but they also have like 3-4" drop. I figure since there will be a big gap between the tire/fender, I can cover those with a beefier tire. Apparently not.
Invader, 205/50 on the same width rim is probably going to have the same height as your current tire.
Old 06-06-2015, 03:44 AM   #7
Yaris_Mac
Drives: Gas saver
Speaking of soft TEIN s-tech suspension. This is my DD and I have a 2yo. Will the ride be bouncy that her head would be bouncing all over her seat? This is the only reason why I've been holding off on buying wheels & lowering springs.
I also have a 2007 Mazdaspeed 3. The ride is pretty stiff with my Eibach springs. Her head doesn't bounce around but it's pretty stiff. Especially noticeable when hitting dips. I'm looking for something softer than this but with 2" drop. I'm hoping s-tech is the spring I'm looking for.
Old 06-07-2015, 12:53 AM   #8
Freestylin
Freestylin's Avatar
The Teins were quite comfortable if I recall. I think your 2 y/o should be fine with it. Stick with 15" wheels preferably nothing wider than 7" and a high offset (anything above +42) if you are actually going to drop it. This setup will allow you to run a higher profile tire such as a 195/55 or 185/60 series for road comfort. The offset I recommended will provide you the wheel clearance you need from the tires rubbing the fender liners / fenders if you hit a large dip or do some spirited driving with the Tein S-techs. Please keep in mind that once you get these lowering springs you should also purchase some aftermarket struts/shocks with them. Using the Tein springs with the OEM struts / shocks will lead to premature failure of the struts / shocks as they are not "stiff" enough.
Old 06-09-2015, 01:00 PM   #9
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I run Tein S-techs with 15x6.5" (+40) Konig wheels (I also run a 10mm rear wheel spacer). The ride is stiffer than stock, but not bad, especially compared to the rock-hard Megan Racing coilovers I used to run.
I only rub the driver's side fender liner on hard bumps. It's a very good daily-driving setup.
A 15x8 +25 wheel, however, you'll probably rub a lot and would need your fenders rolled to help with clearance.
Old 06-09-2015, 11:52 PM   #10
CoryM
Drives: 2009 5-door, 5-speed
If it helps, I run 205/5015 on konig feather (15x6.5, 38mm) and at stock height only rub on hard lock when cornering HARD. And only with Nitto tires (they run shorter/wider than most). My Toyos clear no problem.
Cheers.
Old 06-10-2015, 08:27 PM   #11
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
You will rub with 205/50.
Negative camber is your friend.
WorkTL is offline   Reply With Quote
Old 06-11-2015, 04:30 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
You guys know there is a sticky in this section about different tires sizes and diameters, right?
http://www.yarisworld.com/forums/showthread.php?t=5021
-Derrick-
Old 06-11-2015, 07:18 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
im on teins and 195 55 15 and all good offset 42
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
Increased ground clearance between 2008 and 2010 Sedan unclenefeesa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-17-2013 05:49 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
