![]() Drives: Toyota Yaris Join Date: Apr 2007
Battery swap resulted in blown low-Beam + DRL?
Alright folks, I am confused.
Swapped battery on wife's 09 Yaris LB. That day we go out to a friends house and when we are about to drive back home we realize the low-beams do not function.... I pull engine compartment and under dash fuses (H-LP RH/LH, ECU-IG) all check out fine, visually and with ohmmeter. I then attempt to remove a bulb to check if low-beam filament is busted. My hands are not overly large but my god is it impossible to wrangle the rubber boot and retaining clips loose.... So I popped the clips on the bumper cover and removed the headlight assembly (in <30F darkness, no garage....) and low and behold a blown low-beam filament. I then run to wallyworld for a replacement 2-pack, new bulb works fine! But only when you turn the stick the headlight on position, no DRL! I now do the same thing to the driver side and same deal, blown low-filament and after replacement, no DRL. So whats the deal, could a battery swap cause the DRL module and both low-beam filaments to pop? Or is this simply a bad coincidence? |
| H4 Low Beam HID Kit HELP | SLOWSK8 | Cosmetic Modifications (Exterior/Interior) | 2 | 03-20-2011 09:50 AM |
| Low rpms with a new battery | jaimico | DIY / Maintenance / Service | 8 | 04-08-2010 06:17 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Does anyone know how to rewire a Low beam HID kit, for both LOW/HIGH beam use? | Syroyizhka | General Yaris / Vitz Discussion | 1 | 11-30-2009 10:47 PM |
