Old 12-02-2015, 02:29 AM   #1
jackmilas
Drives: Yaris Verso 1.3 2000 automatic
My "new" 2000 Yaris Verso
Last month I purchased a 15 years old Yaris Verso from a private owner in Berlin. Nicely looked after with a few scratches here and there. It's 1.3 vvti with automatic transmission. When I test drove it I was impressed with how the engine, transmission and suspension worked smoothly. It's only 135000kms. For the past year the owners almost didn't use it and when I arrived battery was almost dead after over a month of not using the car. I thought it might need replacing but after recharging it the battery is perfectly fine.
After I bought it I started learning as much as possible about maintenance. I decided that since the car was very inexpensive to buy I won't be spending on regular service in expensive Toyota dealership.
I already installed daytime running lights (LED) and reverse parking sensor. All of that for less than 100 EUR.
The next step for will be to replace transmission fluid, engine oil and filters. With the transmission I want to replace the fluid 2 or 3 times within next 5000kms to flush as much old fluid as possible. It smells sweet and the color doesn't look bad but it's slightly darker than new fluid.
Currently the engine oil is 10w40. I will be replacing it with 5w30.
Here is the link to my spritmonitor car profile: http://www.spritmonitor.de/en/detail/725585.html
jackmilas is offline   Reply With Quote
Old 12-16-2015, 10:53 AM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Welcome, Jack. Yaris Verso. How interesting. I'd never seen or heard of that model before today. Thanks for sharing.
Old 12-16-2015, 10:57 AM   #3
jackmilas
In Japan it was known under Funcargo name.
Old 02-19-2016, 03:21 PM   #4
jackmilas
Old 02-19-2016, 03:47 PM   #5
ern-diz
ern-diz's Avatar
Old 02-19-2016, 03:49 PM   #6
02echo
02echo's Avatar
Drives: 2002 Echo 4DR Sedan 5SP
Kool car. Thanks for posting.
02echo is offline   Reply With Quote
Yaris Verso dash modification question ladamafia Cosmetic Modifications (Exterior/Interior) 0 06-21-2013 02:30 AM
Bought Yaris 2000 muneeba New YARIS Purchase Forum 7 04-27-2009 01:07 PM
