Old 06-13-2016, 06:58 PM   #1
Bill18
Drives: Yaris 2007
Kit Blitz from japan
Hi everybody, i buy a Blitz kit from RHD japan and last saturday, i plan to install this in my yaris 2007. When i go to install the support for the alternator, it is not fits in the two holes on the motor. The support is too long. It's arrive under the hole. I mesure the distance between the holes on the support and it's 245 mm compare to the distance on my car 225 mm.
I post a mail to the company and they didn't help me with their response.
Does anybody have a idea to solve this problem?
Thank's
Bill18 is offline   Reply With Quote
Old 06-13-2016, 10:31 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Can you share pictures? I see you only have 2 posts, so you will have to do more to post with attachments.
Old 06-14-2016, 09:31 AM   #3
Do you have the extension piece shown in this picture that attaches the alternator to the main bracket? Flying blind here since you really do need to get some pics up of your situation.
Old 06-15-2016, 07:43 PM   #4
Bill18
Drives: Yaris 2007
Here is some pictures for explaining the situation. Whit the picture in the precedent reply i think it is not the same kit in North America then Japan...
Old 06-15-2016, 07:53 PM   #5
It looks like they sent the wrong kit. I have seen other kits purchased from RHDjapan and they have all looked the same.
Old 06-16-2016, 06:44 AM   #6
could be for a 1nz setup from an xb/echo?
Old 06-18-2016, 07:08 PM   #7
Bill18
Drives: Yaris 2007
I told us in the email that i have the motor 1NZ-FE and the body NCP91. I don't understand why the support in their kit doesn't fit in my car. Does Toyota made two motors 1NZ-FE: one for japan and another for north america??
Old 06-18-2016, 09:19 PM   #8
No.
Did they send you instructions which show that exact bracket mounted?
Old 06-18-2016, 09:45 PM   #9
OK - Found the manual online that shows it (except you can't make out the bottom mounting hole in the poor quality pictures and all of the text is Japanese).
It looks like you have kit 10168/10173, whereas the rest of us have 10182.
https://www.blitz.co.jp/support/manu...73_184_185.pdf
Old 06-19-2016, 07:08 PM   #10
Bill18
Drives: Yaris 2007
Yes, i order the 10173 kit and it suppose to fit in my car because on their website it is for my year model...
Old 06-19-2016, 08:48 PM   #11
As much as I would like to say that the 1NZ for the Vitz is identical to the 1NZ for the Yaris, the short block has a different part number for both: 11400-21220 Yaris vs 11400-21190 for the Vitz of the same vintage. I can't find any pictures good enough to determine of there is something different about the area by the water pump housing, where the alternator and that bracket mount to.
Old 06-19-2016, 09:55 PM   #12
KTS
KTS's Avatar
Drives: Vitz RS
A few things I notice when looking thru the manual:
-The intake manifold looks different,
-The alternator isn't mounted upside down
-The supercharger is driven off the alternator
-A fuel pressure regulator is included in the kit
I hope you get thru with the installation. Keep us posted. Good luck.
KTS is offline   Reply With Quote
Old 06-20-2016, 06:44 AM   #13
The engine cover in the manual also looks more like the 1.8L engine than the 1.5L.
Old 06-20-2016, 10:17 AM   #14
KTS
KTS's Avatar
Drives: Vitz RS
You find? The cover shown is the same exact cover in my 1.5L JDM Vitz RS.
I like how this kit has the supercharger driven off the alternator. This should put less stress on the water pump and crank pulley. I also like the included fuel pressure regulator.
Old 06-20-2016, 07:55 PM   #15
Ah - I hadn't seen a JDM cover.
The replacement alternator pulley is very cool for not using the one tiny belt to drive everything.
Can you snap a picture of the side of the engine where the lower mounting point for the alternator is, so we can see if it looks different than the USDM ones?
Old 06-20-2016, 10:12 PM   #16
Bill18
Drives: Yaris 2007
I think i will try to find a machine shop in my town who can make a bracket that it fit to my car because i don't think the japan will help me to find a solution for my problem...
Old 06-20-2016, 10:24 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
JDM RS 1NZ engine cover. needs jdm valve cover, needs jdm head. :/
Old 07-04-2016, 11:12 PM   #18
johnny_vitz
Drives: 2005 Toyota Echo
The Upper Oil pan is different for the Echo 1NZ vs. Yaris 1NZ...when I replaced the engine in Viperoni's, the wrecker sent me a Yaris 1NZ thinking it would be the same
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Blitz Supercharger Kit AzianCuz Forced Induction Forum 25 08-31-2015 12:54 PM
AI TOY-K969 Install Kit Change Kaykogi In Car Entertainment + Electronics (audio / video / alarm) 2 03-20-2012 11:17 AM
FS: Blitz Supercharger Complete Kit MGargano Items for Sale by private party 27 12-09-2011 12:52 AM
Blending a Kit With a Factory Bezel sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 05-03-2010 12:54 AM
BLITZ HAS CLOSED????? ROCKLAND TOYOTA General Yaris / Vitz Discussion 12 08-13-2009 06:35 AM
