What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Passenger airbag recall/disable airbag?
So it's looking like my 2009 sedan may be affected by the passenger airbag recall. I haven't got any official papers for it but I checked my VIN online and it came up. I'm not sure what all is involved in replacing that airbag, but if they have to pull the dash out frankly I'd rather just disable the airbag and not worry about it rather than risk some dealership breaking my boost gauges and all the other custom stuff I've done to my dash. I know there used to be a device on MI that could disable the airbag and it seems like the passenger seatbelt warning as well. Since MI isn't around anymore, is there another source for these? Some instructions to DIY one anywhere?
Thanks guys.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
I checked my vin recently using one of the links provided in one of the other threads about this and came up on it as well. Thought it was strange that CA was listed as one of the red/priority states. Not sure if that's more about high humidity heat, or number of influential individuals in this state. In any case, I'm hoping for a fix soon. Working from home, I usually only drive my car for going places with my gal, but now we take her car so my car sees very little road time. Bums me out because I enjoy driving my car.
Like you, I haven't received any official paperwork. Unlike you, I wouldn't want a third party or DIY disable device. My mild OCD would still focus on the potential frag grenade behind the dash. I want that thing out ASAP. |
I'm just irritated at this garbage in general. I finally got the last 3 recalls done on my car just for another one to come out. Mark that down as another reason I'm never going to buy anything else made after 1990.
No kidding, eh? Super annoying and from what I understand, they're still installing them in cars today. Total garbage.
#5 | |
#6 | |
Out of curiosity, are you still making/selling that module? |
![]() Drives: 2009 Yaris sedan Join Date: Sep 2015
I have a 2009 Yaris in South Florida, like most of us I need to use my car. So I want this dangerous airbag disabled or removed.
I believe that disabling it will be an open door for insurance companies to refuse any claims filed by the occupant leaving the owner of the vehicle liable for injuries. T is trying to limit their liability by telling owners that no one should ride in the passenger seat. ??Anyone know what the legal ramifications are for disabling the airbag.?? |
#8 | |
http://www.safercar.gov/Vehicle+Shop...tivation+FAQ#1
Drives: Toyota Yaris 2005 Join Date: Sep 2016
So is the passenger airbag bypass plug still available anywhere, or at least a circuit diagram? I've just joined the ranks of super-impressed Toyota customers with a possible IED dashboard, and apparently UK models don't have an off switch either.
airbag
Can I unplug connector(s) and remove the passenger seat so the car still runs and drives?
#11 | |
But that wont work in my 09 Yaris.
If you unplug the connector, you will put the airbag system in an error state where none of your airbags will fire in a crash (including your driver's side ones).
I don't have all of the wiring diagrams for the MK1 European Yaris, and the MK2 ones have a different passenger occupancy detection system than our US ones do, but I believe on the MK1's that the passenger occupancy sensor is just a switch. This switch which feeds the info to the SRS ECU to determine if the airbag should fire in a crash.
#14 |
Airbags
So the Yaris with seat airbag connector unplugged will run and drive without a constant audible warning beep/alarm?
#15 | |
airbags
#16 |
Because the US 2nd gen (aka MK2) Yaris has a occupant classification system for the passenger seat, which actually measures the weight of the passenger at four points between the seat and seat frame and uses that data to determine if the airbag should be armed (and if the seatbelt should be buckled)
#17 |
![]() Drives: BMW Join Date: Aug 2016
____________________________________ Vape mods |
#18 |
![]() Drives: 2008 Yaris 2-Door (White) Join Date: Jan 2014
Replacement Inflators Are In
While letters are not out yet, the replacement inflators are now in stock/arriving at Toyota dealers. Had the recall closed yesterday afternoon on my wife's 08 hatchback here in Knoxville.
![]() Check with your local dealer; you too may be able to make this recall history. |
| Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 17 | 08-16-2024 10:23 AM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 13 | 06-23-2013 04:39 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| Passenger side airbag question | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 01-03-2009 07:54 PM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
