Old 09-29-2016, 08:16 PM   #1
seatech30
Drives: Yaris 2008 Sedan
Exclamation Yaris Sedan 2008 Engine vibration
Hello Everyone,
I've been dealing with this problem for over 30kmiles. When it first started it would only happen while the car was stopped on an incline/slope. Now it does it even when the car is on flat road.
I've replaced battery, spark plugs, cleaned throttle body and MAF with corresponding cleaners, cleaned engine filter, ran injector cleaner through fuel tank twice (BG 44k), and replaced 2 motor mounts. Yet it seems to be getting worse. I have 192kmiles now, and I first began to notice the problem around 30kmiles ago.
I've even tried a different MAF and nothing. I'm currently considering the possibility of a bad timing chain tensioner. I used a timing light on the crank shaft bolt and can see the bolt "shift" position as the car is revved. Is this normal?
Any help will be greatly appreciated, thank you!
seatech30 is offline   Reply With Quote
engine, vibration
Install 2010 Front Grill in a 2008 Yaris Sedan dilandias General Yaris / Vitz Discussion 3 01-21-2016 11:37 PM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 04:02 PM
2008 Toyota Yaris Sedan phenoyz Cars for Sale by private party 3 11-27-2008 08:24 PM
