Old 11-03-2016, 11:16 PM   #3
SirDigby
Drives: 2007 yaris 3 door
you can use a volt meter to check the continuity through the LED. they do burn out sometimes. then check continuity on wiring harness. then from fuse to battery power source.
Tags
cel, check engine light
Check Engine light on after Water Pump change gumby002 DIY / Maintenance / Service 3 03-19-2014 09:06 AM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 05:10 PM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
