Old 02-05-2017, 07:19 PM   #4
tmontague
tmontague's Avatar
I can't remember what supplier it was. I went on eBay to look up control arms for the echo and found a good price and they happened to be Canadian.
The only other front suspension part that you could change (outside of your struts) would be your sway bar bushings. They're possible to access with a crazy long extension from behind the engine in the engine bay but they're not easy. They aren't known to wear so you may be better off to just leave your oem ones in.
I'll be changing mine when I do my 2zr swap but that's only because I'll have the engine out and it'll take all of 10 mins.
In terms of tightening up your suspension just replace all the control arms bushings/ball joint and your sway bar end links. That is assuming your struts are newer
If your steering is also loose then look into your inner and outer tie rods, you also have steering rack bushings which could be worn. That should be isolated to steering though. Have someone try and turn your steering wheel while you look behind the engine at the steering rack. You shoulnt see much play in it at all. Make sure the car is in the ground and not jacked up.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
Front suspension knocking. coffiend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-31-2012 10:58 PM
07 YARIS Liftback FOR PARTS benjomothians Items for Sale by private party 12 02-07-2012 01:53 AM
Front and Rear Suspension nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-27-2009 01:41 AM
Whats a Good Parts Website jthebeh Performance Modifications 2 11-29-2006 08:32 PM
