Old 03-01-2017, 05:29 PM   #1
Pinchlite
Drives: 2007 yaris HB
Seat delete
Originally Posted by David C View Post
I call mine my sporty two seater 2 door white Porsche :p
Envoyé de mon iPhone en utilisant Tapatalk
Details on the seat/bench delete please.
Old 03-01-2017, 05:36 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
+1
That looks like a super clean job.
On Instagram
On Wheelwell
Old 03-01-2017, 06:41 PM   #3
David C
Drives: White '07 3dr LB
I've made a thread which details what's going on underneath the flat deck and the entertainment upgrades involved
http://Power inverter & flat deck (l...6&share_type=t
Regarding the rear bench removal, I simply remove the 4 bolts (two holding the bench structure, two holding the lower frame where the bench just clips in). Then I unbolted the seat belts off the floor and thug the upper sections back into the sides (not mandatory, but I didn't need them to flap around, I'll fish them out when or if I ever undo the rear deck mod). I bolted back the lower frame and a piece of 3/4" plywood on top of it, then 2 block of woods with braces in the front and a old extruded aluminum track in the rear. Then I cut another 3/4" plywood to fit the shape that's widening after the rear wheel wells. The plywood goes from 44" wide to 52" and is 24" deep. I have about 6" to spare underneath the plywood, but installing sound proofing foam panel reduced that to less than 4". I really just used what I had laying around to make that deck and during rainy days when I had nothing to do. Someone else had a thread on a similar flat deck setup, except they went all out and welded a frame for the deck, etc.
I've loaded over 200lbs of cargo on the deck often and its solid. At first I had it popping open toward the front using hinged supports, but it wasn't that useful. Now it's only testing on the supports and held by a screw in both front studs, so it's quick to remove with a screwdriver if you ever need to (which I only did when working in the equipment underneath). I then slid several accessories underneath the deck to store them out of sight and out of the way. In the passenger side next to the inverter, I have a set of booster cables, a golf umbrella, a 12v professional tankless compressor, etc. My main goal was to get all the equipment tucked away and free up as much cargo space. I've slept a few times in the back too on roadtrips.
Pics Pics Pics Jahbs Australia 4 06-30-2010 01:06 PM
HELLAFLUSH III pics contraband831 Photo-Video-Media Gallery 37 01-10-2010 01:11 AM
My Belta, all the way from Pakistan! *many pics/ "mods"* drbilal Photo-Video-Media Gallery 38 05-23-2009 01:43 AM
Snow??? the_boss General Yaris / Vitz Discussion 7 10-22-2008 03:28 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 03:43 AM
