Old 06-08-2017, 11:20 AM   #11
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Originally Posted by Martino View Post
Howdy. Let me start off by saying this is not my car. My girlfriend needed an inexpensive vehicle after getting a job out of town. After some searching, we came across a 5 speed '07 Yaris w/180k kilometers for $2500. Price seemed too good to pass up, so we bought it. Naturally, the car is not without its flaws. They are as follows:
1) It's loud. There is an exhaust leak somewhere, possibly flex pipe
2) Clutch is starting to go. Car needs to be given some throttle before letting it out, otherwise it'll shutter and stall. This'll force the clutch to spin upon engagement, which probably isn't the best thing.
3) Dash is lit up like a Christmas tree. Currently seeing the ABS light and SRS light. Sometimes the battery light comes on and flashes, but it always holds its charge and the alternator is producing power just fine.
4) Left flasher doesn't work. You can turn the stalk to the right and it'll work, hazards also work fine on all corners, but we're getting nothing signaling left. Swapped the underdash relay, that was not the problem.
5) Body isn't perfect. To be fair, this is not the car's fault. My gf gets a new scuff or scratch every week. It doesn't bother her nearly as much as it bothers me, but I thought I'd mention it anyways.
So that's it really. Car is not a garage queen by any means, but I really would like to get it running right for her. Any help or guidance doing so will be greatly appreciated. Thank you in advance, cheers.
Donut gasket between header and cat pipe is likely shot. I just replaced mine that's been leaking for the past 60k miles getting worse as time went and lemme tell you, that gasket was toast! It just fell apart.
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
