Old 07-10-2017, 06:14 AM   #1
sceh
Drives: yaris 2004
A/C advice please
My A/C doesn't work. When I press the A/C button there used to be a drop in revs because the mechanically driven pump was now engaged - presumably through an electrically engaged clutch?
Since my wonderful Haynes manual avoids talking about anything useful (like this or the auto box...), how can I test this? In other words, do you know which wires connect to the clutch so I can see if there is a voltage?
Obviously the voltage could be there IF the computer says there should be and IF the pressure is low then it might say no. If I know the wires, I can force it to at least see if the pump is OK before I add gas.
thanks for any help
sceh is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/c fan operation. mrpj Third Gen Yaris General Discussion 1 03-29-2015 06:57 AM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
