Old 09-08-2017, 11:47 AM   #1
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
First thing you do is to lube the locks! For your problem dry graphite might not work as well as graphite that comes mixed with a liquid lubrication. I personally use White lithium spray lubricant sold by the makers of liquid wrench. Be careful not to spray too much because it will run down the side of the door. I think lubing the locks will fix your problem.
Good luck and tell us what happens!
I have a can off graphite spray good stuff, a new key will be expensive but recomended
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
Old 09-09-2017, 03:10 AM   #2
scylla
Drives: 2015 Yaris L
Sounds like the OP has a chipless key. Same as I have and it cost $3 at walmart. I picked up an extra couple right after I bought my car. I even zip tied one to the under carriage just for an emergency.
I agree. Graphite is a wonder drug for stubborn locks.
scylla is offline   Reply With Quote
Old 09-09-2017, 08:19 PM   #3
RedSuns
Drives: 08 Yaris
Yup its chipless, i got my replacement key copied at the hardware store for $2. Can't complain with that. The graphite is great too, the actuation and movement is much smoother.
RedSuns is offline   Reply With Quote
Old 09-09-2017, 08:36 PM   #4
hairygityeti
Sir Rustalot
I have one ignition key (with transponder) and 2 ordinary keys for door locks i realy must get a spare ignition key cut!
New remote key fob programming costica DIY / Maintenance / Service 1 04-17-2016 09:02 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
key wont turn out of lock position Drummer829 DIY / Maintenance / Service 10 09-22-2012 02:34 PM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 01:01 AM
Driving wheel doesn't lock when taking off the key Pingouin General Yaris / Vitz Discussion 5 09-09-2010 12:15 AM
