Old 09-22-2017, 10:32 PM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by hairygityeti View Post
I had the same problem and purchased an "Erbauer" 6 piece bolt remover set for £12 and it work amazingly well,some bolts had hardly any head but it still worked with out effort. I did the change over myself purchased a second hand ( like new ) manifold fr£30 and gasket set for £8 im no mechanic but i did it within an hour.
I'm glad you were successful at removing your bolts. It just wasn't a job I was comfortable doing. After watching a number of videos since, I think I would probably give it a try if I was facing the job again. I guess all the heads of the bolts just crumbled when he tried to remove them. I believe he used a mig welder to build up the bolts that were flush with the head in order to get something to grip onto. However, as much as I didn't want to spend that kind of quid on the job, I'm still within my budget.
The tech did also say that he removed an axle and a motor mount and titled the engine forward to give himself more room to work.
Dang... My shop got a very nasty yet comical poor review on yelp YarisSedan Off-topic / Other Cars / Everything else Discussions 37 10-03-2010 02:51 PM
August 2nd Mosport DDT lapping event. 2009-10th Touge.ca lapping event! Touge.ca Canada 1 07-30-2009 03:12 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
November 2nd, Sunday - Mosport DDT lapping event, Last event of the season!! Touge.ca Canada 0 10-31-2008 12:45 AM
