Old 11-14-2017, 10:24 AM   #11
yaris2011-07
Drives: 2008 yaris hb ce
Thanks! I think the jury is out on how well electronic rust protection works. My former principal, who is a long time shade tree mechanic, swears by them. He gets them installed on all new vehicles. A few years back I convinced him of the merits of using an oil-based rust proofing compound in interior panels, rockers etc, etc and he adopted it as an annual maintenance item. He uses it in conjunction with the electronic module. His cars are all relatively new - none more than 5 - 6 years, so it's hard to tell which if any approaches stopped the rust. There wouldn't likely be any rust anyway as they are so new. I know that you will find a lot of debate regarding these electronic systems. Apparently they work very well on bridges and boats where a complete circuit is present. They theory is sound apparently, just much debate about how well they work in an automotive application.
I have not closely checked the control arm bolts but I did coat them in Rust Check Coat and Protect. Everythng seemed fine but I'll pop a wrench on them and check. Thanks for the heads-up!
If you've never removed the control arm bolts before, and if they require alot of torque to remove, I would recommend heating up the bolt head for about 10 minutes with a propane torch before putting alot of torque on those bolts.
I broke a 3/8" ratchet on the driver's side bolt. Then I used a 1/2" ratchet and that broke the bolt head off. I think if I would have torched the bolt head first it may have come off without breaking the bolt head.
Of course heating up bolt head may destroy your rubber bushing...so you need to decide if this approach is best for you.
Once I broke the bolt head off I needed to drop the subframe to get at that bolt. In the process, I ended up destroying the control arm bushing, and ended up replacing the control arm.
I coated the new bolts with lithium grease so I hope they will last another ten years!
Good luck!
yaris2011-07 is offline   Reply With Quote
Rear cabin grommet carbine2 DIY / Maintenance / Service 0 04-28-2014 06:02 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
MY RUBBER BAND BALL! AGHHH!!! Sodium Duck Off-topic / Other Cars / Everything else Discussions 47 03-06-2009 01:56 AM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
Noise coming from rear end! tfman716 General Yaris / Vitz Discussion 15 10-28-2008 12:37 PM
