Old 12-09-2017, 11:20 PM   #433
yaris2011-07
Drives: 2008 yaris hb ce
Originally Posted by tmontague View Post
How was the broken bolt extracted?
Yup, looks bad. I needed to drop the subframe and then heat up the bolt bolt with a propane torch. Once heated, I used a good pair of vise grips and was able to remove the bolt.
The most difficult part of this procedure was getting the control arm bushing to release the bolt since the bolt was rusted solid to the bushing sleeve.
yaris2011-07 is offline   Reply With Quote
Old 12-10-2017, 08:21 AM   #434
dogsridewith
Drives: 2007 2-door hatchback
Warning - Broken control arm bolt! subframe Mind of Toyota
I think this may happen because Toyota skipped a drain hole(s) somewhere. I did an oil change in dry conditions a day after I'd washed the car or there had been a rain event. Car on a lawn sloping somewhat nose down. Drove front wheels up on low ramps to level for oil change. Some time passed in steps of the oil change. And here's water dripping from that subframe area! (pretty sure I checked to see that it wasn't coming from the rubber HVAC tube)
(Warning - Broken control arm bolt! subframe Mind of Toyota)
Old 12-10-2017, 07:21 PM   #435
tmontague
tmontague's Avatar
I had the same issues on my '05 vibe when I replaced the control arms, took an extra 6hrs and I ended up having to burn out the bushing and enlarge the subframe hole to fit the metal insert through. It was seized so bad I never got it unstuck. An impact was useless as the bushing dampened the impacts.
Now on any car I own I pull the control arm bolts and antiseize the whole thing so it never seized to the bushing sleeve. Takes some time but saves hours down the road
Old 12-10-2017, 08:53 PM   #436
yaris2011-07
Agreed. Some extra drain holes or extra sealing to prevent water from entering the bushing sleeve would help to prevent this situation.
Old 12-10-2017, 09:01 PM   #437
yaris2011-07
I also ended up burning part of the bushing while lowering the subframe.
I torched the bushing sleeve a number of times, so the heating and cooling process along with alot of hammering on the bushing sleeve helped to release it from the bolt.
Old 02-01-2018, 03:27 PM   #438
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
I'm trying to show a local shop theses pictures and its useless linking this thread cause you dont display the images without signing up first.
thanks
Cartel is offline   Reply With Quote
Old 02-02-2018, 12:31 PM   #439
thetut
Drives: 2007 4dr sedan
Right click on the image.
Select "Copy"
Open Paint program
Select "New"
press Ctrl + V
Save file and copy it to your phone or tablet.
Show it to your mechanic and let him revel in the destruction.
thetut is offline   Reply With Quote
Old 02-02-2018, 06:20 PM   #440
Billiam
Drives: '10 White Yaris 4D LB
We bought a '10 LB a couple of weeks ago with 126k on it. The 1st thing I did was change the oil to some M1 High Mileage 5/30. The 2nd thing I did while it was on the ramps was to check these infamous bolts. I was very nervous putting the breaker bar on them. Thankfully they both came out with out any drama. Despite water dripping from the passenger side hole when the bolt was removed, both bolts looked great. I lathered them completely in antiseize as well as the holes and reinstalled them.
I'm way out of warranty and on my own. So checking these will be part of my regular maintenance
If you want to enjoy your car, stay off of the internet.
Old 02-02-2018, 10:33 PM   #441
Cartel
Cartel's Avatar
Well I ordered the bolts.
Toyota argued with me about the part number and how they are non-returnable.
Apparently 90119-14126 was superseded by 90119-14144 and 90119-14151 wouldn't match up for him, he basically talked me into getting the 14144 bolts.
I pulled mine out, the drivers was pretty loose.
I then dipped the new bolts in marine grease from top to bottom and made sure they were really gooped up with excessive amounts of grease and put them in.
My car has under 45,000KM on it so they were not bad.
The bolts were $26 CAD for both.
I cranked the wheel to one side and layed beside the car to get them out without lifting it.
I wanted the garage to just inspect mine while getting a wheel alignment next week but decided to just replace them myself first.
The new ones only had 1 mark compared to 2 on the original.
Old 02-03-2018, 11:27 AM   #442
tmontague
tmontague's Avatar
those are in decent shape, keep them as spares just in case
the marine grease has worked well for me and I now only check them every couple of years as the water seems to keep away from the marine grease really well
Old 07-04-2018, 02:27 PM   #443
Whiplash
Drives: 2009 Yaris 4DR
Post.
Whiplash is offline   Reply With Quote
Old 07-04-2018, 03:52 PM   #444
dogsridewith
Originally Posted by Whiplash View Post
Post.
exactly
Old 07-05-2018, 07:30 AM   #445
Whiplash
I have some reading to do.
Old 05-01-2019, 09:38 PM   #446
tmontague
tmontague's Avatar
bumping up an old thread. I was installing some subframe collars today and pulled my control arm bolts I replace 3-4 years ago. I hadn't pulled them since 3 or so years ago. Well they look brand new with zero rust on them. All I did was coat the thread and the neck of the bolt in anti seize and then coat the neck in marine grade grease. The grease squeezes out when you tighten the bolts back up but that stuff is sticky and keep the water that pools in the area from contacting the metal.
apparently this is a great method of keeping the rust away.
this is after it was wiped off, it was crazy dirty.
Torque spec on the bolt is 118 ft/lbs
*take note* the bolt neck is what corrodes and snaps off so anti seize on the threads is a good idea for corrosion resistance but it will not fix the underlying rust issue with these bolts. Coat the bolt neck in marine great which is sticky as heck and will not allow water to sit against the metal and corrode it
Old 05-02-2019, 02:46 AM   #447
komichal
Ah, thanks for reviving this thread. It reminds me that I need to check it on mine as well.
I have no idea whether my car can have this problem or not (VIN code: VNKKL98310A....) So it seems I have to go for visual inspection.
Local winters are salty so I may have some issue with this.
Old 10-18-2019, 09:03 PM   #448
RCRobymar
Drives: Yaris Hatchback 2008
Smile Squeaking Lower Control Arm - FIXED!
Hello Everybody,
I just got these two bolts replaced (TOYOTA Part #: 90119-14126) after dealing for some time now with a squeaking noise coming from the front suspension of my Toyota Yaris 2008 (Hatchback) while driving over a speed bump or an uneven surface.
I just came back home after driving it for 10 minutes around the neighborhood and the problem seems to be gone! :)
Tip: Before screwing the new bolts in, I submerged them in heavy duty grease to keep water and rust away for as long as possible.
I hope it helps all Yaris Owners out there!
RCRobymar.
RCRobymar is offline   Reply With Quote
Old 02-11-2020, 05:01 PM   #449
kenora
Drives: 2009 Yaris LE 5 dr
I'll add a bit to this old thread...
I will add a bit of a curve ball to the front end issues with the Yaris.. it could be MORE than just the LCA bolts..
I have a 2009 Yaris HB 4dr LE with 180000 km (about 115000 miles).. almost exclusively highway and a 3 season vehicle. In the dead of a Manitoba/NW Ontario winter we drive a 2010 F--d Escape AWD.
In Oct, just before the Hamster (name we gave the Yaris) went into the garage for the winter I noted a constant clunking coming from the left front when going down gravel roads (I'm in central Canukistan..gravel IS considered an acceptable highway material and often better than asphalt).
After much checking I concluded (incorrectly) that it was the left inner tie rod end since grabbing the tie rod and yanking would get some movement ...so I bought a new inner TR end and the tool to remove/install it... In mid November (in the garage) I started work and found that it wasn't the inner TR, instead the drivers side mount for the steering rack had corroded and broken off, leaving the entire rack supported only by the pass side mount.
These are long 11mm (shaft dia) with a 17mm head (top) and 17mm nut on the bottom of the car.
The DS nut was hanging by dirt and rust and the whole rack would move with a small push/pull.... I was PI--ED OFF knowing it could have killed me at anytime and couldn't figure out what was up.
I unhooked the tie rods and the steering column then TRIED to remove the broken bolt from the D Side of the rack ....
well it's nearly unreachable as it mounted behind the steering input shaft (the designer should be beaten!) making getting a tool on it next to impossible... the PS is easy to get to.
Anyway after a ridiculous amount of frustration I got the rack out with the DS bolt still ruster into the bushings metal sleeve.. then into a 10 ton press (could NOT press it out) so then into a giant vise to hold the metal sleeve with a HUGE impact gun.. this finally got the bolt to spin in the metal sleeve and out it came (I'll post pictures).
I ordered new bolts and nuts ($42 CDN with taxes) and spent a day reassembling everything....
Well the Hamster came of the garage today as I set off for a front end alignment (tie rods had come off...) HOWEVER it STILL CLUNKED... just like before the steering rack odyssey so I turned around and put her (the hamster) back into the garage and set about searching this site and stumbled on this thread,,
I was able to get both mounting bolts out without breaking them and found them both in awful condition BUT not nearly as rusted as the steering rack bolts...
so.... I've ordered new 19mm LCA mounting bolts ($25 CDN) and will install those next week when they arrive from the centre of the Cdn universe ... Toronto :)
It would be wise to keep in mind they the idiots that brought you sh-t LCA bolts also did the same on the smaller and more fragile steering rack bolts...
btw..Toyota wanted $2200 (or more...its always more) to fix the rack...
kenora is offline   Reply With Quote
Old 02-11-2020, 05:12 PM   #450
kenora
well it looks like I did some house cleaning and got rid of the steering rack bolt pics but here are the LCA bolts... the passenger side shaft has eroded (rusted away) more that the other but I'm glad I'm changing them..
If some needs to see the steering rack bolts I can take another pic ... I saved the bolts to show friends the crap Toyota put in these cars..
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
