Old 04-20-2018, 11:02 AM   #3
Pinchlite
Drives: 2007 yaris HB
With the drums off, can you see any movement in the shoes when you apply the ebrake?
If not, then I'd say you have an issue involving the cables that connect to the one that feeds away from the ebrake handle. If there is movement in the shoes, then the star wheel needs massive adjustment.
Yes,but handle must be moved to the sky.
I just reassembled everything and might make appointment.Something is seriously wrong/broken.
About the star wheel it cannot be turned down anymore.Its at the end of its limits somehow.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Yaris with rear disc brake from factory? tamrat DIY / Maintenance / Service 18 01-19-2016 09:08 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
