Old 08-29-2018, 09:03 AM   #27
tmontague
tmontague's Avatar
That seems like a ridiculous amount of foaming and bubbles in coolant.
I'm surprised you to all the cost and trouble to do a head gasket without doing a leakdown test. Get a leakdown test and see what it shows. You could have a warped head which would make the new head gasket useless if that is the problem.
The coolant will spill over as the temp increases that is normal
Tags
cooling system, overheating
1nz turbo with recipe! speedworxs Forced Induction Forum 61 06-27-2019 04:00 PM
Polishing 1NZ Throttle Body rabbito Performance Modifications 3 02-25-2016 11:36 AM
1nz Disassembly & Reassembly. EchoLaQua Forced Induction Forum 0 06-19-2015 11:17 AM
Overheating problems scumfromohio DIY / Maintenance / Service 24 04-18-2014 02:09 AM
ATX temperature overheating? yaryarbing Fuel Economy Forum 7 05-07-2011 09:24 AM
