Old 09-13-2020, 01:03 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Rustproofing the Yaris Hatchback
I dug up this pic of the Yaris underbody. Since I'm in the process of doing some extensive rust repair on my newly acquired '07 RS 3-door, I figured I'd post this.
The hatchbacks are prone to corrosion in the rear subframe, rocker and dogleg area.
There are 3 distinct and fully separated cavities that can collect water and rot out. Each area has an access plug. Using a 360 degree pattern rust proofing tip and a thin rustproofing compound, these areas can be protected.
I did not draw the arrow at the front or the line at the rear axle. Those were on the pic when I found it.
Old 09-13-2020, 09:49 AM   #2
ex-x-fire
I have a long flexible tube that Napa gave me when I bought fluid film from them.
Old 09-14-2020, 07:04 AM   #3
06YarisRS
Yes! I bought one of those a long time ago. Unfortunately, the 360 degree tip came off when it got caught in something in the rocker panel. I did get several good applications, though, before it broke. I think I just got impatient and tugged too hard on it. It worked great though.
I just ordered one of these. I guess it's ok, but doesn't spray FF well. That's fine as I plan to spray thin ATF in the panels. Or, I'll thin down some FF and try that. Since it doesn't come with a bottle, I'll buy some product with right sized bottle, then use it with ATF or similar.
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
Old 09-14-2020, 10:06 AM   #4
tmontague
tmontague's Avatar
Thanks for the image. I'll triple check next spring that I sprayed these areas on my sedan. My car now only sees summers being track only driven now, but due to its age I will still be coating it from the bottom every spring.
I did the doors and everything up top already and don't 0lan on redoing that portion.
Old 09-14-2020, 02:37 PM   #5
Great share!
Old 09-14-2020, 04:37 PM   #6
06YarisRS
Yeah, it's a good pic to illustrate the locations. It's too bad Toyota didn't promote rustproofing in these areas. It's really the only locations that suffer appreciable rust damage. Your sedan is fortunate to no longer have to face Canadian winters!
Old 09-14-2020, 04:37 PM   #7
06YarisRS
Great share!
Thanks man!
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
Yaris hatchback is rare in da islands bradbowl Hawaii 27 08-04-2018 01:49 AM
FOR SALE:USED TRD (Toyota Racing Development) Muffler for 2007 Yaris Hatchback - $150 Cigar_Maverick Items for Sale by private party 9 06-13-2018 02:39 PM
Human error in Yaris hatchback sherlockholmes DIY / Maintenance / Service 3 04-23-2018 11:10 AM
