Old 05-05-2021, 05:31 PM   #1
Bluebaby
Drives: 2007 3 door
BETTER fuel economy at recommended tire pressures
I got an '07 3-door manual a few months ago, my first car of my own. The clearcoat's fucked but I don't love her any less because of it.
Since then I've been running between 36-38 psi because that'll get me better fuel economy right? At between 6.5-6.9L/100km between fillups (I normally fill about 400km into a tank), I was pretty happy.
Wrong. 2 fillups ago I lowered my 2 month old 175/65/14 Hankook Kinergy ST's to the doorjam-recommended 32psi, curious about how much more fuel I'd use. To my shock, over the first 400km I got 6.0L/100km on the dot. I was skeptical, thinking the pump I'd used for that fillup cut off earlier than other ones. But today I went back to the same pump after 350km of driving and recorded 6.1L/100km. No changes in driving style, weight of the car, other maintenance, nothing. Only the tire pressure changed.
Might go lower them to 28 and see if I get 5.5
Bluebaby is offline   Reply With Quote
Old 05-06-2021, 07:01 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Whats the ambient temp there in your place? It has been noted in several discussions that during winter you will normally get poor mileage.
rayfloyd170 is offline   Reply With Quote
Old 05-06-2021, 04:43 PM   #3
KALISPEL II
KALISPEL II's Avatar
Drives: '26 Mazda 3 Select-Sport Sedan
I averaged 41-42 MPG over the 4 year ownership of my 2015 Yaris SE 5-MT hatch, & always had my tires at 34-35 PSI. Here in AZ, USA it doesn't get cold enough for it to affect MPG really, so it remains consistent year round.
2026 2.5L NA Mazda3 Select-Sport Sedan 6-AT FWD (w/Chrome-Delete) - Soul Red Crystal Metallic - Built in Japan
KALISPEL II is offline   Reply With Quote
Old 05-06-2021, 06:10 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Too many variables in play. Summer gas perhaps? There is a direct relationship between MPGs and tire pressure. You are describing an inverse relationship. I don't see how this is possible. I don't doubt your numbers but there must be another explanation.
Old 05-07-2021, 08:02 AM   #5
Bluebaby
Drives: 2007 3 door
Can't say I kept track, of the weather, though temperature here in Nova Scotia fluctuates wildly on a day-to-day basis. I got about 7-7.5L/100km in winter conditions with winter tires for the first 3 or 4 weeks of ownership, then it was all season time. Since then, it's been anywhere between 0-15 degrees C on any given day.
Old 05-14-2021, 11:39 AM   #6
Neinris
Drives: 08 Yaris 3 Door Hatchback
I have a manual transmission and are on 185/60R15 tire/wheel combo, every two weeks that I fill up I check and maintain 33psi in my tires. I do a lot of city driving, and I have a leaded foot, so I'm lucky to see 32mpg (7.35/100km). I only saw 40+mpg (5.88-/100km) when I drove from Maryland to California, thanks to the cruise control that I installed. I only got pulled over once when I was in Texas for going 80 on a 75?!! Oh and I was on the far left lane when I was the only one on the road.
Instead of messing around with the tire pressure, why not just buy bigger tires next times when it's time to replace them? 185/65R14 or get new wheel and tire combo 185/60R15.
Neinris is offline   Reply With Quote
Old 01-12-2024, 11:47 AM   #7
WaGah
Drives: Man
Send a message via AIM to WaGah Send a message via Yahoo to WaGah
Your experience with tire pressure and fuel efficiency is intriguing. Have you considered checking the alignment of your wheels or exploring other factors that might influence fuel consumption, apart from tire pressure? Additionally, what made you choose to lower the tire pressure initially, and have you noticed any changes in your driving experience with the adjustments you've made?
WaGah is offline   Reply With Quote
Old 01-25-2024, 05:58 AM   #8
HobbsFraks
Drives: Man
Send a message via AIM to HobbsFraks Send a message via Yahoo to HobbsFraks
What made you choose to lower the tire pressure initially, and have you considered checking the alignment of your wheels or exploring other factors that might influence fuel consumption, apart from tire pressure?
HobbsFraks is offline   Reply With Quote
fuel economy, hypermiling, tire pressure
Need help and suggestions about bad fuel economy BT91 Fuel Economy Forum 18 11-29-2015 05:22 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
How to improve my fuel economy? Murtaza_murti Fuel Economy Forum 21 04-21-2011 02:48 AM
mud guards vs. fuel economy fenerli Fuel Economy Forum 22 04-16-2011 07:59 PM
