![]() Drives: 2010 Toyota Yaris 3D LB Join Date: Oct 2021
Thanks for the suggestion! However, my clips looked fine and the ends of the trim clipped in nicely.
I worked the trim with my hands to straighten it out more and used a heat gun when installing it again. The trim went in better (still kinda loose in the middle) but it doesn't vibrate while driving so I'm happy with how it is. If it does come loose I'll drop some Sikaflex-221 under the trim. I think the trim also helps prevent water from pooling at the weld seams and causing rust over time. |
| Tags |
| 2010, drip, molding, roof |
| Roof drip molding | patm | Cosmetic Modifications (Exterior/Interior) | 6 | 01-11-2017 09:55 PM |
| Roof drip molding moving | romram | Cosmetic Modifications (Exterior/Interior) | 9 | 04-01-2015 07:29 PM |
| Roof drip molding | patm | DIY / Maintenance / Service | 1 | 05-20-2013 12:31 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 10:03 AM |
